Gimbal calibration in Litchi?
Hi all,
As the title says really. I can't find gimbal calibration in litchi .... Guessing it's not a feature? The trouble is when I calibrate in the Go app, then close and open Litchi .... the gimbal is waaaaay off centre, way way off!
Thanks
Phil
Hi Phil,
Have you had a look under the C1/C2 Button Options?
Either button with Short or Long Press brings up a Dropdown Menu : Reset Gimbal.
HTH, Cheers Al.
Hi Phil,
HTH, Cheers Al.
Resetting the gimbal is not the same as calibrating it. Resetting it just returns it to 0 degrees. Calibrating fine tunes the operating parameters.
Daniac
