FPV HUB mounting issue
Hi all, new to the forum and as a first post just wanted to ask advice,
I have a Phantom 2 with gimble sporting GoPro 3 black, have recently installed a FPV setup using the DJI 5.8, iOSDmini, and FPV HUB, to keep things clean I have removed the top of the Phantom and installed all components inside the Phantom except the TX which is outside on the left hand side of the frame (pictures attached to show) now the issue I have is that the cables supplied with the HUB are not that long and as a result mounting locations are restricted, it's left me with the antenna facing straight forward out of the front of the Phantom.
So my question is: is there a longer cable to go from the HUB to the TX that is available and if so where from? Or alternatively is there a right angle connector that joins the antenna to the TX again if so where from? Reason being is I have a little too much interference (for my liking) coming up on the screen when flying and wanted to see if having the antenna on the TX facing straight down would make much of a difference...
Much regards and thanks in advance.
robvalduga
