- Joined
- Jun 6, 2017
- Messages
- 35
- Reaction score
- 8
- Age
- 42
DJI Phantom 3 Professional 4K Drone in Excellent Condition + Lots of EXTRAS. Based in London, UK can post at an extra charge. £800 ono.
Bundle includes:
Below are the drone features and specs.
DJI Phantom 3 Professional Quadcopter Drone
• High capacity 4480mAh S4 battery giving a good flight time of 23 minutes so you can enjoy more of your flying time
• Without a permit, the legal range for a drone to fly is below 120m and always in the line of sight from the operator
• Check out The Drone Code or The IAA (ROI) for everything you need to be aware of when flying your drone
• Camera records in ultra-HD on a 4K resolution camera for clearer videos and awesome aerial photography shots
• Three-axis gimbal provides improved accuracy when rotating the camera
• The Lightbridge system gives you a huge 2km range to connect your smartphone or tablet so you can view the camera footage live in 720p resolution
Special Features
• Advanced autopilot gives you the option to automatically take off, rise to a pre-set height as well as return to the starting position with the press of a button
• Download the DJI Pilot app to live stream your flight to YouTube so you can show off your flying ability to your friends
Download the DJI Pilot app so you can live view your footage
What makes this drone different from the others?
The DJI Phantom 3 Professional is vastly improved from the previous version. The range at which you can fly has been greatly increased from 1km to 2km*. Double the range gives you a further field of flight making your aerial photography even more impressive. As well as this the drone has a better hover accuracy than the Phantom 2 with only a ± 10cm vertical and a ± 1m horizontal accuracy. This compares to a ± 80cm vertical and a ± 2.5m horizontal accuracy on the previous version, giving you more accurate positioning as you are flying.
What quality of camera does the Phantom 3 come with?
This particular drone comes with an Ultra-HD 4K camera that gives you a maximum video recording resolution of 4096 x 2160p at 25 frames per second. This gives you a fantastic looking picture as you soar through the skies. For still photography, the camera boasts 12 megapixels giving you the capability of high quality shots for those sweeping landscapes. As well as this, the camera can also stream live in 720p HD straight to your smartphone or tablet. This works over the maximum 2km range by utilising the DJI Lightbridge image transmission technology.
What is the advantage of having a three-axis gimbal?
The three-axis gimbal that comes standard with the Phantom 3 gives you more stability and more control when using the camera for videoing or even still photography. The gimbal is fully controllable from the remote controller and the dedicated DJI Pilot app giving you smooth and stable footage as you fly.
What advantage does using the autopilot have?
The autopilot feature on this drone allows you to make the most of the advanced automatic elements with the push of a button. The Phantom 3 will automatically take off, rise to a pre-set height using the DJI Pilot app and hover in the set position until you take over. As well as this it also has a return to home mode where if the battery starts running low or you lose connection it will enter its failsafe mode and return to where you initially took off from. This saves you having to search for the device if anything was to happen whilst you were in mid-flight.
Safe flying is your responsibility
We fully encourage safe and responsible flying. We recommend you read the CAA’s/IAA’s website and The Drone Code for full information on safe and responsible flying.
The CAA (UK)
The IAA (ROI)
The Drone Code
Specifications
Weight (including battery and propellers) 1280 g
Diagonal size (including propellers) 590 mm
Max ascent speed 5 m/s
Max descent speed 3 m/s
Hover accuracy Vertical: ± 10 cm
Horizontal: ± 1 m
Max speed 16 m/s
Max altitude above sea level 6000 m
Operating temperature 0°C to 40°C
GPS mode GPS/GLONASS
Camera
Sensor Sony EXMOR 1 / 2.3inch
Effective pixels 12 MP
Lens FOV 94° 20mm (35mm format equivalent) f/2.8 focus at 8
ISO range 100 – 3200 (video) 100 – 1600 (photo)
Shutter speed 8s – 1/8000s
Image max size 4000 x 3000
Still photography modes Single Shot
Burst Shooting – 3/5/7 shots
Auto exposure bracketing Yes - 3/5
Bracketed frames at 0.7EV bias Yes
Time-lapse Yes
Video recording modes
UHD 4096 x 2160p (24/25 FPS), 3840 x 2160p (24/25/30 FPS)
FHD 1920 x 1080p (24/25/30/48/50/60 FPS)
HD 1280 x 720p (24/25/30/48/50/60 FPS
Supported SD card types microSD
Max capacity 64 GB (Class 10/UHS-1 rating required)
Max bitrate of video storage 60 Mbps
Supported file formats FAT32/exFAT
Photo JPEG, DNG
Video MP4, MOV (MPEG-4, AVC/H.264
Battery
Capacity 4480 mAh
Voltage 15.2 V
Battery type LiPo 4S
Max flight time Approximately 23 minutes
Bundle includes:
- DJI Phantom 3 Professional Drone (Quad-copter)
- DJI Phantom 3 Professional Remote Control
- DJI Phantom 3 Pro 4K Camera with Three-axis gimbal
- DJI Phantom 3 Pro Battery charger with with power cable
- DJI Phantom 3 Battery (x1)
- DJI Phantom 3 Manual + 7 month DJI warranty
- DJI Phantom 3 NEW (sealed) 4 x propellers
- Extra DJI Phantom 3 Battery (x1)
- Tablet Monitor Sunshade Hood (see picture)
- DJI Phantom 3 E305 9450 Props Carbon Fiber Reinforced Self-tightening Propellers (x4) (see picture)
- Neewer® for DJI Phantom 3 - Filter Accessory Kit: (3)37MM Filters (CPL+ND4+ND8) + (1)37MM Filter Adapter (see picture)
- Anbee Carbon Fiber Gimbal Guard Plate + Lanyard (see picture)
- DJI Phantom 3 Quick Release Propeller Guard White (x 4) (see picture)
- Extended Landing Gear Protector Kit Lengthened Heightened Landing Skid For DJI Phantom 3 (see picture)
- 32GB SandDisk Mirco SD card for DJI Phantom 3
- QUADRA-BOX® case for DJI Phantom 3 (see picture)
Special Features
The CAA (UK)
The IAA (ROI)
The Drone Code
Specifications
Horizontal: ± 1 m
Max speed 16 m/s
Camera
Time-lapse Yes
Photo JPEG, DNG
Battery
Capacity 4480 mAh
Voltage 15.2 V
