First WP Mission - failed. No Pictures taken
Hi,
the p3se has completed her first wp mission today. i planned a route with multiple waypoint and added two actions for every wp:
-stay 3 secs
- take photo
the first action were completed, but i got no pictures...
What could I have done wrong?
litchi up to date...
here a part of the csv from mission hub:
latitude,longitude,altitude(m),heading(deg),curvesize(m),rotationdir,gimbalmode,gimbalpitchangle,actiontype1,actionparam1,actiontype2,actionparam2,actiontype3,actionparam3,actiontype4,actionparam4,actiontype5,actionparam5,actiontype6,actionparam6,actiontype7,actionparam7,actiontype8,actionparam8,actiontype9,actionparam9,actiontype10,actionparam10,actiontype11,actionparam11,actiontype12,actionparam12,actiontype13,actionparam13,actiontype14,actionparam14,actiontype15,actionparam15,altitudemode,speed(m/s),poi_latitude,poi_longitude,poi_altitude(m),poi_altitudemode
52.xxxx,11.xxxx,30,0,0.20000000298023224,0,0,0,0,5000,1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-1,0,-
sorry for my bad english :)
Were you running video for the mission? I seem to recall that it won't take photos when doing this. Also, if the mission has curves it can prevent actions (the waypoint is never 'hit')
Reactions: P3Noob
@gingerbloke
your absolutly right! i checked again the mission on my pad, there it shows "actions disabled on curves" - the mission hub does not show this hint!
thank you for this tip. i will test the mission again, when the weather is better.
i removed the curves, the csv now have the actions, but in curvesize is a value? is this ok?
52.xxx,11.xx,60,175,0.20000000298023224,0,2,-12.058166323305025,0,3000,3,3,1,0,2
Can't help with that as I've only ever used litchi for video so far, anyone else chime in?
I'm about to start some stills litchi projects (if the weather plays ball) so I'm staying on this thread.
the answer from litchi via fb chat:
Hi,
Be sure to check our online guide at : upload_2018-2-14_13-31-53.gifhttps://flylitchi.com/help#waypoints-p3
Actions are performed when the aircraft arrives at the waypoint. There are six different waypoint actions, three of which accept an additional parameter.
You can add up to 15 different actions for each waypoint.
Important Waypoint actions are ignored when the mission "Path Mode" is "Curved Turns" as the aircraft will not stop at waypoints then.
hcashmore11
