Extender wifi not show
Hello
Am using Android phone 4.4.4 after success binding camera extender restart but wifi not showing.
Phantom 2 vision plus
Hello
if the wifi isnt showing then the rebind hasnt worked,
resetting the range extender
hold in the reset button
the system light must go out and stay out for at least 8 seconds, if it comes back on start again
once done the wifi will show on the phone
go through the binding process,
if you enter the wrong MAC address then this will also cause the issue
you must use the correct MAC address, it is the one for the wifi module, best bet is to open the quad up and read the MAC address from off the top of the unit.
or you can use a windows program called INSSIDER
the SSID will be a hidden one and the MAC address starts with 60 60
here is a video guide for INSSIDER
Reactions: Mark The Droner
Thank you
I find difference between the mac of hiden wifi and the mac in the camera qr code
I used the mac of hiden camera but after binding wifi not showing again
Thank you
What device are you using to bind, I find that anything over android 6 is pretty much useless, if you have an IOS device or can get one use that
Am using Iphone 6... I tried again wifi working now very well but no live view
I opened the drone and unplugged the antenna live view back but when plugged everything live view stopped again
jeetbuzz360
