Hello people, can we extend our battery capacity? Currently, my battery status shows 4020mah left. Is there a way to extend this without replacing a new battery? Thank you!!!
Before plugging in charger SWITCH on battery - then plug in charger. Battery being on when charger connects over-rides the high point limit. It allows charger to work till battery is full, even though battery is near full.
If that does not show better results - note despite some claims that the board in front of battery is 'clever' - it aint that good !! It counts charge in ... charge out .... and after a while the counter' is at fault over successive cycles.
You will now get various posts about deep discharging and re-calibrating the battery ...
I am not a fan of deep discharge - but if only done occasionally and NOT every 20 charges as some still hang to ... then it will reset the counter if battery discharged and recharged. It does not increase battery - it just resets the counter giving the appearance of increased capacity.
