Custom Cut ND Filters for Phantom 3
Southern California
ND filters cut with a CNC machine to fit under the existing P3 Camera lens cover..I use some of the best GEL material available, Kodak Wratten and Tiffen GEL material that are more resistant to fingerprints and can be easily wiped clean without scratching.
The cost for a set of 2 - ND90 3 Stop filters is $5 shipped to anywhere in the US...
I will also ship International and will research the rate to your destination so you do not over pay for postage.
Just start a conversation with me on the forum by right clicking on my name and in the popup click on Start a conversation.
Safe Handling Instruction for the filters are as follows:
As with any camera equipment we want to try and keep it clean and dust free as possible..
My suggestions and how I handle my filters is to use a set of non-powdered latex gloves, I carry a pair in my camera bag and also in my P3 case. I also carry a lens cloth with me which can be had for very low cost if not free from your local camera store.
Prior to each flight and as part of my pre-flight check :
1. Gauge my lighting conditions I will be flying in and choose how many filters I will be needing to keep my frame rates in check.
2. Gently remove my Glass lens cap and glass lens cover.
3. Use my lens cloth to clean the glass lens cover prior to inserting the ND Filters also in this process and before wiping the glass lens cover I give it a quick blow of air in case there is any particles that may scratch the lens cover when I wipe it with my lens cloth.
4. Pull out the required number of filters and again give them a little blow of air and I usually hold them up to the light and look through them to be sure they are clean if not use your lens cloth and give them a light wipe, the Wratten and Tiffen GEL can be wiped clean of fingerprints and any other debris.
5. Place the lens with filters installed back on the Camera housing and lightly screw back on until snug , Please be careful to not over tighten.
6. I always give the front of the glass lens cover a quick look and wipe if necessary to be sure it is clean.
7. Go FLY and Enjoy.
Wood like to order
@fkehler - I do ship internationally and like to get a destination so i can provide an accurate shipping charge and I don't want to over charge anyone for shipping. I started a personal conversation with you so we can discuss..
@Longranger - I stated a personal conversation with you to discuss
Hi John
I live in San Diego CA
Can u give an accurate cost?
Thx
Hi John
Thx
Longranger did you get my personal conversation request, look in the top right corner of this forum there is what looks like a little envelope you will see a number next to it that is a personal conversation if you click the envelope you will see your personal convo requests and you should see mine there..
Hello,
I am interested in the ND filters as well, shipped to 02895. Please let me know if that is possible?
Thank you
Another high-five for these filters............ tried them over the last 2 days and they work great!
Just received my shipment the other day, haven't had a chance to test them yet.
A+ for Dataway for providing such a cheap and useful service to these forums.
Dataway is it hard to take off the lens cover on the p3?
No it should not be to difficult to unscrew the lens cover off of the camera on your P3, I found if you use a rubber band or something similar to get a better grip and use light pressure and twist counter clockwise not squeezing too hard that usually does the trick..
shimuafeni fredrik
