Controller Usage
HWB
Can any controller be used on any aircraft? And if so is the linkage process the same as for a loss connection re-linking? I ask this question because I have a practically new controller I would like to try and see if it helps my weak signal problem?
For a P3S, the controller needs to be a GL358wA. If that’s what you have, then yes it will work when linked.
If you are talking about other models, in this post is a compatibility chart I created a while back.
cokersean20
