I'm getting in on this late, but just wanted to say that the replacement compass is dirt cheap, AND they send you a new leg...no idea why they send the leg, but they do.
Not sure what 'way off' refers to.
The GPS can provide location, ground track, speed, and altitude. The compass provides you heading.
These really don't compare so what do you mean?
Thanks for mentioning that.I'm getting in on this late, but just wanted to say that the replacement compass is dirt cheap, AND they send you a new leg...no idea why they send the leg, but they do.
I have same problem too with my Phantom 2 V+ 3.0. I thought it caused by the defect compass component. I keep flying with GPS mode and its work well, but I'm worrying it is a potential problem without have a normal calibration.
henryten - do you mean keep waving a magnet near the compass and re-calibrate the compass can solve the problem ?
Not sure if the fixing procedure is same with this:
Is there any testing we can do to observe the healthiness of the compass ?
A GPS can give compass bearings as well, but only if you move. You'd have to walk with the bird for a short distance so the GPS can work out; "You were THERE, and now you're HERE, therefore you travelled in xyz direction".
It could then compare THAT to what the compass says, and work out if the compass is screwy. It could only do this while moving, but could do it.
Morning Gentlemen. I have the same exact problem henryten had. I was able to get rid of the red lights/low voltage/calibration failed alarms by repeatedly re-calibrating by getting dizy and also re-calibrating in the Assistant software. I took my P2V+ up and things seemed ok but not perfect. Now I'm away from home and she's all over the place. A steady hover is a thing of the past. I'll be back home in a few days and get things straightened out but I sure would like to send her out on a few missions. Do you think I risk a flyaway?
I don't want to break up the good info you guys have been posting. But I wanted to toss something in that maybe nobody knew about, or has yet to mention it, but did you know the gps puck has a battery. And if that battery goes bad weird things may happen. The battery as I can remember is meant to over come hiccups with in the system. These hiccups happen often and without logged data that refreshes 250ms or faster you wont see it happening. The batteries are not replaceable either. You basically have to replace the puck altogether unless you find a replacement battery and solder. There is more details to know on this subject, but its one that I haven't posted about recently so I don't remember everything.
Also, another subject that needs considered in this thread is the pressure sensor and how it relates to the compass.
Forgive me now if I forget to follow up on this. I seem to be spending time that I always spent here but now in the P3 forum.
Looks like you may have to make sure your Phantom is very level when you re-calibrate. And even then, you may have to do some tweaking.Good point. And that would explain the kind of "jinking" around I saw: GPS moves vehicle, discover the error and temporarily compensates.
Perhaps worth mentioning.....
when you do the compass dance dont hold the quad by placing your hand over the top/covering the gps... otherwise it might go green but because your blocking the satts it will flash red leading you to think compass calibration failed....
best to hold it by an arm or something...
Caught me out when I first started doing it... so figured i'd speak up lol...
I see I may have missed your point. At first it seemed you were saying covering GPS would result in a failed compass cal. My apologies Sir.Errr how its not true?
If you place your hand over the gps antenna... after the compass calib it will flash green and then flash red seems its lost satts....same as if you cover the gps at any other time?
Ive been able to hold the arm for both parts of the calibrarion.... to be clear I dont mean landing skid.. i mean the arm?
How are you not able to hold the arm for both parts... the thing wieghs like 1kg... ?
What are you saying?You'd think that DJI would have addressed this flaw.. the GPS and compass argument.
If the compass is way off compared to GPS then throw an alert red lights etc..
