Cheap controller mod
So as I said in my last post I would post how to make your own £20 or $25 if your from us
So you need
2 x Mini PCI U.FL / IPX to RP-SMA Female
2 x Alfa 7 dBi gain RP-SMA directional panel Wi-Fi antenna
1x Star screw driver
1x drill and drill bit I used 5 mm and worked up till fitted
1x some glue
after you get that use the screw driver and open your controller WATCH THE WIRES there are loads of tuts of youtube how to open after you opened it take the back half where the battery is and take of the silver stand and where the stand was drill a hole to get the Mini PCI U.FL / IPX to RP-SMA Female to fit in after you do that undo your old 2.4ghz panels from the controller and plug your new wires in.
After you did that make sure the bit sticking out the controller is safe so I used a load of glue to keep it in after that plug the wires back in and put it the way it was
This is how it should look I did add the stand on after I think it looks better with out but I drilled the hols for it
Imgur: The most awesome images on the Internet
ODIN Reviews
