- Joined
- Jun 25, 2015
- Messages
- 24
- Reaction score
- 3
- Age
- 39
If you have a power supply that can supply higher amps it shouldn't be a problem. Where are all the electrical engineers at haha
The factory charger is just a power supply that never stops supplying voltage - it's always there (assuming it's plugged in). The current draw is based on the individual battery's Intelligent charging circuitry.I agree with this.. but how do you plan to connect them all together in parrallel without having access to the male connector? How will they behave when one finishes charging before another and the power supply doesn't stop supplying voltage?
Are you sure about this? How do you know that?This is not the case for the DJI Phantom 3 Intelligent battery. The battery has the charging, regulation and cell balancing circuitry built in. All we do is supply a power source and the intelligent battery does the rest.
Having to wait 4 hours for 3 LiPo's to finish charging is not ideal and this is all that I've seen available online. While I don't like babysitting them either, I would not feel comfortable with leaving them unattended for that long.. Someone needs to make a charging bar that can be connected to a suitable power supply so that all can be charged simultaneously.
A well known company in the RC charging arena, ProgressiveRC, is our best bet for a potential manufacturer of such a product. I think there's plenty of demand, they just don't realize it yet. Maybe if enough of us ask them to add this to their product line, they will change their mind..
There are a few simple ways to know this for sure.Are you sure about this? How do you know that?
1 - The DJI web page for the battery, here http://store.dji.com/product/phantom-3-intelligent-flight-battery states "Integrated power management and balanced charging capability"
2 - The "charger" has only 2 contacts, lacking the necessary balance inputs.
3 - The "charger" actually has printed on it "AC power adapter" and "power supply", but nowhere does it say "charger".
Sorry man, I meant voltage on the battery contacts, not the power supply.Yes there is voltage without battery...
The moment you plug in...
Yah, it's just a good regulated power supply. But pretty much everything has the charging circuitry built in these days anyway, including the tablets we all use on the P3.Since DJI does not publish any useful information on this matter we all have to guess.
However having said this the balancing is done in the battery not in the charger.
A charger can be anything that delivers power.
The DJI-charger is internally stabilized (educated guess). I have measured the voltage with a oscilloscope. Without any loading approximately 17,5 V. With a 2 amp load still 17 volt and only a small ripple. This small difference and small ripple says that the charger is internally stabilized.
I wil measure later how big the current is if you load an near empty (10%) battery.
The charger is rated as a 100w charger but if you take the full 100w out of it over a longer period the charger will burn out. Thats for sure. Just think on a 100W bulb, how hot these guys get and they have a much better heat dissipation than our charger.
A charger for four batteries must deliver around 400watts stabilized. A good and a safe (overload, overheat protection ect.) one will be expensive.
You don't have to be a rocket scientist to operate one of these, but it would help if you are. It takes a lot of learning, reading and research to be up to snuff on one of these. There are guys that stay on this forum all day long. They live and breath Phantom. I don't know when they have time to actually go out and fly, because no matter when I check in, they are here.Ha. This is all way over my head. I will continue to read and once a viable solution is apparent then I will follow suit. Enjoying this very much.
