Can you change the camera lens?
sbarton said:
I don't like the fisheye, nor do I like having to fly so close to get a good pic. Is there a way to upgrade the lens on the Vision+ to something better without a fisheye?
-Scott
That's kind of the idea, you're not suppose to be zooming in on people on the ground. They're for aerial shooting. Not zooming.
Even the GoPro upgrade lens do not allow you to "zoom" or take a picture from far away. If you want to take a picture of something low to the ground, you better hope you have permission. :D
Try the resulution options and they have the second wheel right side of resolution wheel where the symbolic suggests a change between 16:9 and 4:3. My impression is that as the resolution stil remains the same (eg. 1080p) it stays with 16:9 but the wide angle (140degrees?) changes to standard (110 degrees?) Which does of course a lot less fisheye effect.
Have to verify it again, only found out this afternoon and now sitting lazy on couch....
I use narrow view all the time and am happy with the results.
My vision+ in narrow and 1080p, no editing or fish eye removal in this video.
[youtube]https://www.youtube.com/watch?v=l1SM9JE08JM[/youtube]
Agree, it seems be be a very good option
SpikeFinch said:
Select the narrow view option and your all set..
+1 The narrow FOV setting does not completely remove the fisheye effect, but it reduces it substantially.
You are correct, it's still there some, but a lot better and it's a quick mid-flight change.
I sincerely hope they give us a much higher quality camera on the 3, whenever it comes out. Watching ANY of our videos in 1080 looks like standard def, due to the quality of our cameras. It's frustrating, when there are such good small CCDs out now.
This effects video only, it doesn't alter the photos. :(
I feel like i read somewhere that setting the FOV to narrow basically just crops off the sides of the image. Is that true?
In what cases do people use the narrow setting versus wide? Thx
I've had good luck using a program called Prodrenalin (by ProDAD) to process the barreling and 'fisheye' effect on both the P2V+ camera and the GoPro. There are presets to correct the the lens distortion and straighten things like the horizon lines. Check out these two videos for examples. http://www.prodad.com
https://vimeo.com/106017070 (side by side test footage of telephone p[/vimeo]ole with wires)
https://vimeo.com/106899008 (Gas plant footage)
The Gas Plant footage has a lot of piping and such and the lines are basically straight. Note the horizon line - it's basically straight.
Guy
Prodrenalin does work well. I use the Generic GoPro profile and it effectively de-fishes the video quickly and cleanly. It can also color correct and stabilize.
