- Joined
- Jan 10, 2016
- Messages
- 153
- Reaction score
- 23
So i just found out that the 2 video feed antennas are located inside the AC and are visible if you remove the battery. I was suprised to found that the actual transmitter us in the gimbal and the antennas ports are located there as well. It's also very easy to change the antennas.
By removing these two small things (undoing 2 screws for each) you can reach the antennas ports. I'm wondering whether you can put any 2.4GHz antennas there to get better signal. So please help me with this. Also the 2 antennas that are clearly visible on the landing feet are the RC antennas. To get to that you'll need to open the shell and you will clearly see the two antennas ports as well. But i think those antennas are just fine. My question is: I'm getting an ARGtek controller mod and it's supposed to give me beter range and stability of signal, but i'm wondering whether it will give me more if i replace the 2 video antennas on bird. Also do you think the rc antennas on bird are good enough or they need to be replaced too? Thanks
