Battery capacity
Just curious about what your total battery capacity is on your phantom 4. Original battery only.
Mine are
4298 mah
4832 mah
5414 mah
Wondering if the lowest one is about to take a dive
They typically don’t Dive.
Slowly fade.
how deep do you discharge? so far my deepest discharge is down to 58% I dont usually go past that level. I charge right after every trip.
If your coming home with your packs around 50% charge I wouldn’t put them into the charger again until I expected I would need them to fly with.
Reactions: N017RW
Mine are
4298 mah
4832 mah
5414 mah
Capacity loss is only one indicator of serviceability. How the battery performs under load is important, significant voltage imbalance between cells, excessive temp rise and collapse under load are suggestive of a problem.
mikeyduhaime
