Argtek on my P3S - Poor range
Discussion in 'Standard/4k Discussion' started by vinicius.anjos, May 7, 2016.
  1. vinicius.anjos
    Argtek antenna installed on my P3S, but the signal is much worse than the original antenna. I installed correctly and made sure that the cables are correct. someone help?
  2. Procharged97
    Canterbury, CT
    Do you have a pic of the inside of rc where the uf.l cables clip into the board? I know you said you installed it correctly and im not doubting you but you have to make sure you get all the dji glue off around the board and make sure the new uf.l connectors "click" in place, then glue them down
    dirkclod likes this.
  3. vinicius.anjos
    [​IMG] removed the glue
  4. vinicius.anjos
    [​IMG] clicked is ok!
  5. vinicius.anjos
    [​IMG] fixed with glue
  6. Procharged97
    Canterbury, CT
    All looks good
  7. Procharged97
    Canterbury, CT
    I know i only got about 1200-1500 ft more depending on where i was flying and had them angled. I wasnt very impressed with it so i ended up buying the DBS itelite.
  8. Procharged97
    Canterbury, CT
    What did you get stock for distance vs. The argtek??
  9. vinicius.anjos
    Argtek = 180m
    Original = 480m
  10. sudarwika_bali
    Bali Indonesia
    hi, same problem, today im tried argtek on my p3s but total dissapointed. stock 500m and argtek 500m to. same place, tried multiple time. but only 530m. plz help.
  11. Procharged97
    Canterbury, CT
    I say ditch the ARGTek and get DBS
  12. Procharged97
    Canterbury, CT
    Maybe one of the wires is crimped/messed up on the inside of the mount bar? Or maybe fakes? Is it to late to return it??
  13. sudarwika_bali
    Bali Indonesia
    whether there fake ARGTek? Can you explain a little bit? or maybe can give us a picture? fake and genuine?
  14. sudarwika_bali
    Bali Indonesia
    need your help. if I get fake one, I will be back to stock antenna.
  15. Jfasig
    Will a Terminator or aMaxxrange work on a standard
  16. Procharged97
    Canterbury, CT
    It will work for the 2.4 side of it..you would still need an antenna for the 5.8. Im going to eventually run the maxx or terminator unboosted and a 5.8 helical boosted.
  17. Procharged97
    Canterbury, CT
    There were some being sold with legit box but the actual antennas were blank. Before i bought mine awhile back my buddy said to watch out for them...if they have the correct labels I would inspect the mount bar that contains the 3 sma connectors...there should be 2 screws you take out to separate and check. Something is definitely wrong with it for distance to be worse than stock with the argtek. I can pull my ARGTek box from the basement tomorrow and send pics of box and antennas if you want
  18. Procharged97
    Canterbury, CT
    Ive never seen the "fakes"..this was just something a buddy told me. I can post pics of mine with box if you'd like. Do you have pics of your setup?
  19. Shawn Prigmore
    I started with the Argtek as well and was disappointed with the results. Installed the itelite DBS and am pleased with the results. My main reason for the modification was to increase the quality of the live feed, which is great now. If your looking for good range extension I think you would be happy with the DBS.
    Cheers,
    Shawn
    Procharged97 likes this.
  20. Jfasig
    that sounds great.What brand of helical and booster do you recommend? Thanks
Similar Threads - Argtek P3S Poor Forum Date
P3S Antenna cable broke. Should I go with an ARGtek General Discussion Sunday at 1:38 PM
P3S For Sale + Extras With ARGtek Extender Installed Classifieds Jun 26, 2017
Will P3s RC stable without hotglue cable after Argtek mod Standard/4k Discussion Nov 12, 2016
ARGtek Range Extender for P3S Brand New Classifieds Oct 12, 2016
P3S with Argtek range extender Classifieds Sep 5, 2016
