Now that I finally received my new vPlus V3 (refurbished), I can get back to.....the good stuff. After digging around some in the app I was able to stumble upon the .csv files for 2 flight loggers. One is app related, and the other flight logger focuses on the Quad itself. The app related logger will most likely not be used in any way. The Quad Flight Logger is full of Super Data!!!
kenargo has taken advice very well up to this point and we will have the perfect setup once it's finalized. Most importantly the flight logger is currently able to read and used to diagnose most all issue. There is some data that is currently not yet on it, but should be easy to include. The current downfall of this flight logger is that none of the data can be used with Dashware. If it's possible, the names of each data column will need renamed in order to be used with the profile logger in dashware.
I have taken some screen shots showing what data is currently on kenargo's Ultimate Flight app. You wont see the full data name is some of the columns. I was going to break it down but knowing the names need changed I decided not to. Btw, for this Flight Logger to be most powerful, we need the names to match the names found in the Flytrex flight logger. These loggers need to co-exist with one another in the way of name language. If for some unknown reason that these names can not be changed, as last resort a completely new logger profile will have to be created/built. Should that happen, none of the current 100 or so gauges we've been using, will able to be used.
The data in the images is from my quad which was recorded while sitting and not moved. Because of this you will see nothing recorded. The "0".
This image shows data that you see in the app. As I say it's .csv file will most likely not be needed or used anywhere.
