Which controller is best gl-300b or gl-300c
I have two phantom 3 p one I guess is a little newer then the other. Just wondering if there is any difference in range or performance between the two models. Tia.
I saw a post in here once that showed the different transmission power of the gl300 a, b, and c remotes and if i recall correctly the A version had slightly higher power than the b and c which were the same. Other than that i know of no other differences.
I think this is the post you saw. I've had it book marked. The B&C are almost identical units. The A apparently had longer range and power output.
RF power measurements
Here's something I recently printed to add to my "Manual Folder"
300A & 300B RC's both have the same power output for the control signal It's only the 300C version of the RC that has reduced power.
The 300A RC has the Davinci processor and USB 2.0 B & C don't have the internal video processor, but do have USB 3.0
GL300A controller frequency range 2404.00000000-2480.00000000
Power Output :0.380000 Watts
GL300B controller Frequency range 2404.00000000-2480.00000000
Power Output: 0.380000 Watts
GL300C Frequency range 2404.00000000-2470.00000000
Power Output: 0.3030000-Watts(80% of 300A &300B's output)
Reactions: Mark The Droner
W323 P3P
Freq range 2406.50000000-2476.50000000
Power Output: (0.7460000 Watts)
W323A P3P
Power Output: (0.6120000 Watts) (82% of the W323's output)
W323B P3P
Freq range 2406.50000000-2476.550000000
Power Output: ( 0.5200000 Watts) (70% of the W323's output)
I will add that the Power Output is also restricted by software. Especially in CE areas, the power is much more attenuated.
In dji-firmware-tools, there is a tool which allows to remove the attenuation from GL300 Main Controller firmware (m1400).
Reactions: Phantom2USA
Thanks all for the input all very helpful
side question. If I am looking for a replacement controller for my p3 Pro, should I get the 300A for the Davinci processor or the 300B for the USB 3?
Honeymoo
