- Joined
- Oct 30, 2014
- Messages
- 31,963
- Reaction score
- 10,787
- Location
- Harrisburg, PA (US)
- Website
- phantomhelp.com
I've compiled a list of the top Phantom 4 accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Phantom 4 owners are buying and using.
Fstop Labs Landing Pad
Notable features:
DJI High Capacity Phantom 4 Battery
Notable features:
ENGPOW Fireproof Lipo Bag
Notable features:
HUL Aluminum Carrying Case
Notable features:
PGYTECH Drone Landing Pad
Notable features:
DJI Low-Noise Props
Notable features:
Yx Parallel Battery Charger
Notable features:
DJI Goggles
Notable features:
Hooshion Lanyard
Notable features:
DJI HDMI Output Module
Notable features:
Ultimaxx Backpack
Notable features:
Powerextra Backpack
Notable features:
Hooshion Antenna Range Extender
Notable features:
RCGEEK Tablet Mount Extender
Notable features:
RCGEEK Sunshade
Notable features:
DJI Sunshade
Notable features:
DJI Remote Controller Strap
Notable features:
Want to check out more Phantom accessories? A commonly used list of Phantom accessories sorted by category is available at PhantomHelp.com.
Notable features:
- 30 inches wide
- Made of a waterproof nylon material
- Includes stakes to ensure the landing pad stays in place
- Fold up and store in the included storage bag
Notable features:
- Created, designed, and extensively tested by DJI
- Guaranteed to work well with your Phantom since the battery is an OEM DJI accessory
Notable features:
- Made of silicon coated fiberglass with heat blocking aluminum foil inside
- Large enough to hold multiple Phantom batteries
- Keeps batteries safe while charging, traveling, and storing
Notable features:
- Aluminum frame construction with ABS plastic panels
- Can store the Phantom with the props attached
Notable features:
- 20 inches wide
- Weighted to keep it in place in windy conditions
DJI Low-Noise Props
Notable features:
- Guaranteed to work well with your Phantom since the props are an OEM DJI accessory
- Slightly quieter prop noise
Notable features:
- Charges 3 batteries simultaneously in about 80 minutes
- Able to charge the remote controller
- Anodized aluminum case offers a non-conductive layer
- Ground earth connection for safety
DJI Goggles
Notable features:
- Dual 1920 x 1080 HD screens
- Integrated touchpad to navigate through menus within the goggles
- HDMI input and 3.5mm audio jack
- Up to 6 hours of battery life
Hooshion Lanyard
Notable features:
- Made of high tenacity nylon
- Adjustable length
Notable features:
- Output 720p live HD video stream to an HDMI device
- Commonly used to display video on goggles or a second screen
- Includes Mini-HDMI output port, Micro-USB port, USB port, and a CAN expansion port
Ultimaxx Backpack
Notable features:
- High quality water resistant nylon exterior
- High density EVA foam interior to shield your gear from impact-related damage
- Can hold the Phantom, remote controller, 3 batteries, charger, and other small accessories
Powerextra Backpack
Notable features:
- Hard exterior shell and EVA to protect the contents
- Padded and breathable mesh back panel for comfort when carrying on your back
- Small enough to fit in an airplane overhead bin
Notable features:
- Boosts the remote controller signal to increase its range
- Folds closed for storage
Notable features:
- Extends the remote controller mount to allow larger 10 inch tablets to be used
- Solid plastic design (not 3D printed)
RCGEEK Sunshade
Notable features:
- Shades your mobile device screen from sunlight
- Folds up for easy storage
- Small magnets hold the sunshade closed when folded
DJI Sunshade
Notable features:
- Collapsible and easy to carry
Notable features:
- Off-load the weight of the remote controller when flying for long periods of time
- Adjustable straps
- Store in the included storage bag
