- Joined
- Oct 30, 2014
- Messages
- 31,977
- Reaction score
- 10,801
- Location
- Harrisburg, PA (US)
- Website
- phantomhelp.com
META-REVIEW: Complete list of Phantom 4 features & what people are saying about it
Phantom 4 features
Accessories
Battery
Camera
DJI GO
Flight Modes
Performance
Phantom
Remote Controller
Findings after flying the Phantom 4
Camera
Flight Modes
General
Performance
Notes
Where to buy a Phantom 4
The Phantom 4 can be purchased from DJI, Amazon, Apple, Best Buy, and other DJI dealers.
Review Sources
The following reviews were used to compile the information above:
Eric Cheng: drone.farm/phantom-4-announce
RC Geeks: www.rcgeeks.co.uk/blog/dji-phantom-4-unboxing-and-first-look
Romeo Durscher: www.visual-aerials.com/phantom4.html
The Verge: www.theverge.com/2016/3/10/11193354/dji-phantom-4-drone-review
Know of a good review that's not listed above? Please comment below so I can include it in this meta-review.
Phantom 4 features
Accessories
- Comes packed in gray styrofoam carrying case [Verge]
- Carrying case is good for storage, but not durable enough for traveling [Romeo]
- Carrying case layout is very efficient & does not leave much extra room [Romeo]
- Carrying case can hold 3 batteries (one stored in the Phantom) [msinger]
- A smart device (up to size of an iPad Mini) can be stored in front of carrying case [Romeo]
- Battery charger is a 100W charger running 17.4V [RC Geeks]
- Battery charger uses a new 10-pin design [RC Geeks]
Battery
- New battery is shorter and wider [Romeo]
- Battery snaps into place snugly and detaches easily [Verge]
- P3 battery (4 cell 4480mAh, 15.2V, 68Wh) vs P4 battery (4 cell 5350mAh, 15.2V, 81.3Wh) [Romeo]
- Battery has ventilation holes between the layers to aid cooling [RC Geeks]
- White battery charger connects to bottom of battery [Romeo]
- Battery life averaged 25 minutes [Verge]
- DJI advertises 28 min flight time, but got 31 min on one flight [Romeo]
- Takes 70+ minutes to fully charge [Romeo]
- RC can be charged at the same time as the Phantom battery [Verge]
Camera
- Camera glass improved for sharper image around edges & less chromatic aberrations [Romeo]
- 8-element lens reduces chromatic aberration by 56% & lens distortion reduced by 36% [RC Geeks]
- Camera has 20mm (35mm equivalent) f/2.8 lens with a 94° Field Of View and it sits above the 1/2.3” 12MP sensor [RC Geeks]
- Can shoot video in 1080p at 120 frames per second [Romeo]
- P4 uses same camera sensor from P3 [Eric]
- New camera lens supposed to yield sharper images & better colors [Eric]
- Camera uses same sensor, but has better glass lens and can do 1080/120fps [Eric]
- Incredibly smooth footage [Verge]
DJI GO
- New icon added to left side of DJI GO app to access flight modes [Romeo]
- Colored bars displayed at top of DJI GO app to show how close are to an object [Romeo]
- DJI GO now shows an object detection visual indicator [Eric]
Flight Modes
- Includes same intelligent flight modes as P3 (POI, Follow Me, Waypoints, Home Lock, Course Lock) [Verge]
- Intelligent Flight Modes renamed to Smart modes [Eric]
- New autonomous flight features (ActiveTrack & TapFly) [Verge]
- ActiveTrack = lock onto target and keep in frame [Verge]
- TapFly = tap on the screen and P4 flies in that direction [Verge]
- Obstacle avoidance when P4 is moving forward [Verge]
Performance
- 22 MPH top speed when object avoidance is enabled [Verge]
- 35 MPH top speed in normal flight mode [Verge]
- 45 MPH top speed in Sport mode [Verge]
- DJI claims 5 times more stable than P3 [Verge]
- Extra stability due to dual IMU & downward facing cameras & sonar sensors [Verge]
- Much more stable than P3 [Romeo]
- Improved hovering capabilities up to 10m above ground [Romeo]
- Horizontal hover deviation decreased from +- 1.5m to +- 0.3m [Romeo]
- Tilts forward up to 45 degrees when in Sport mode [Romeo]
- Can identify current positions more accurately & hover in place more precisely [Romeo]
- Increased reliability with dual IMU & compasses [Romeo]
- VPS works up to 10m from the ground [Romeo]
- Increased max ascent and descent speed in Sport mode [Eric]
- Can detect objects that are up to 15 meters (49.2 feet) away [Eric]
- Holds exact position within 1-2 inches in moderate wind [Verge]
- Offers more robust feature set than Inspire 1 & can match its speed [Verge]
Phantom
- Aggressive & attractive design [Verge]
- Glossy plastic exterior [Verge]
- Thinner more aerodynamic body [Verge]
- Belly is gray plastic [Verge]
- Motors have prop locking mechanism [Verge]
- New props push on and lock for easier installing [Romeo]
- Looks more aerodynamic & slightly more aggressive feel [Romeo]
- Glossy finish gives classy & sporty appeal [Romeo]
- About 100g heaver than P3 [Romeo]
- 2 downward facing monocular cameras & 2 ultrasonic sensors [Romeo]
- Front facing optical sensors create depth map to calculate distance of objects [Romeo]
- Redesign gimbal lock attaches to landing gear [Romeo]
- Grooves in rubber landing strip are used to position the gimbal lock [RC Geeks]
- Vision Positioning System upgrade from 3 to 4 sensors [Romeo]
- Motors are higher to help keep props out of your shot [Romeo]
- Micro SD card slot moved to side body for easier access [Romeo]
- Gimbal integrated into body & moved to center of gravity [Romeo]
- Retains similar basic Phantom design [Eric]
- Top of P4 is extremely plain with a too-clean look like a de-badged car [Eric]
- Bottom of P4 is sleek making P4 look and feel extremely polished [Eric]
- New cleanly mounted 3-axis gimbal using 2 motors to control pitch [Eric]
- Front of P4 has 2 stereo vision cameras to detect & avoid obstacles [Eric]
- 2 front-facing cameras & 2 downward-facing cameras for subject tracking & object detection / avoidance [Eric]
- Camera sensors field of view: 60º vertical, 30º horizontal [Eric]
- 100 grams (0.22 lbs) heavier [Eric]
- Composite bottom for structural integrity [Eric]
- Micro-SD card and micro-USB port moved to body from gimbal plate [Eric]
- Motors same propulsion specs but pushed out of the mount, which allows for better cooling [Eric]
- Grills for cooling vents on bottom of arms [Eric]
- Redundancy: dual IMUs and dual compasses [Eric]
- New quick release props [Eric]
- Latches at end of each arm are for snap-on prop guards [Eric]
- Arms contain air vents in location where LEDs were normally placed [RC Geeks]
Remote Controller
- Same RC & Lightbridge connection as P3 [Verge]
- RC P-F-A switch changed to P-S-A ("S" is for Sport mode) [Romeo]
- RC play button changed to pause to easily pause autonomous flights [Romeo]
- RC device holder upgraded to Inspire 1 metal mount [Romeo]
Camera
- Video stream extremely clear & lag free [Verge]
- Video team thought video footage looked more raw (which will allow more flexibility when editing) [Verge]
Flight Modes
- TapFly does not work when too low to the ground [Verge]
- When using TapFly, P4 will flight to max distance setting in DJI GO app [Romeo]
- ActiveTrack would often say subject is too small or far away when trying to lock on [Verge]
- ActiveTrack worked best when 10-12 feet from target [Verge]
- ActiveTrack lost person when crossing paths with person wearing same colors [Verge]
- ActiveTrack lost person when wandering into a group of people [Verge]
- ActiveTrack could easily orbit person by holding stick to left/right [Verge]
- ActiveTrack gets lost in direct sunlight, large shadows, clothes that match surroundings [Romeo]
- When using ActiveTrack, P4 will not auto adjust altitude if subjects is walking up stairs [Romeo]
- Object avoidance is disabled when flying in Sport mode [Romeo]
- Obstacle avoidance will navigate around obstacles in emergency RTH [Eric]
General
- Great for both amateurs & pros who want to take complex/dangerous shots [Verge]
- Best overall drone in terms of reliable flight, beautiful footage, and build quality [Verge]
- New pilots will be able to easily start flying [Romeo]
- Much harder to crash than P3 [Eric]
- Good for documenting yourself doing an activity in outdoor environment with no obstacles [Eric]
Performance
- On RTH, always landed within a few inches of takeoff position [Verge]
- Autonomous flight eases into turn to produce smooth footage [Verge]
- Breaking distance greatly increases when flying in Sport mode [Romeo]
- Very stable when flying indoors [Romeo]
- Cannot make tight turns while flying with autonomously [Verge]
- Obstacle avoidance is sometimes too cautious and refuses to fly desired route [Verge]
Notes
- HDMI output module from P3 is compatible with P4 [Romeo]
- P3 ND filters fit P4 [Romeo]
- Prop guards might obstruct vision sensors [Eric]
- New autonomous flight modes are not foolproof, so don't rely on them [Eric]
- Phantom 4 will not be supported by 3rd party apps (e.g. Litchi & Autopilot) for some time after launch [Eric]
Review Sources
