META-REVIEW: Complete list of Mavic features & what people are saying about it
msinger
Approved Vendor
Harrisburg, PA (US)
Website
phantomhelp.com
Mavic Pro features
Battery
  • Max Flight Time: 27 mins (0 wind at consistent 15.5 MPH) [DJI specs]
  • Average Flight Time: 21 mins (in normal flight with 15% remaining battery level) [DJI specs]
  • Battery Type: LiPo 3S (43.6 Wh) [DJI specs]
  • 3830 mAh LiPo battery charges in about 1 hour [Scott Simmie]
  • Charger includes 2 USB ports; can charge remote controller at same time [Scott Simmie]
  • Can charge with advanced charging hub plus P4 100W charger (takes 130 minutes to charge 4 batteries from 15% to 100%) [Dr Turbo]
Camera
  • Stabilized 4K camera [DJI]
  • 2x digital zoom [blade strike]
  • Smallest-ever 3-axis gimbal for shake-free photos & video [DJI]
  • Autofocus camera with minimum focusing distance of just 19 in (0.5 m) [DJI]
  • Turn camera 90 degrees for vertical selfies/video [DJI]
  • Records 4K video at 30fps & full 1080p HD at 96fps [DJI]
  • 12-megapixel camera with Adobe DNG RAW support has been tuned for aerial images [DJI]
  • Can shoot 2-second-long exposures [DJI]
  • Camera Sensor: 1/2.3” (CMOS) [DJI specs]
  • Effective Pixels: 12.35 M (12.71M total pixels) [DJI specs]
  • Camera Lens: FOV 78.8° 28 mm (35 mm format equivalent) f/2.2; Distortion < 1.5% Focus from 0.5 m to ∞ [DJI specs]
  • Shutter Speed: 8s -1/8000s [DJI specs]
  • ISO Range: 100-3200 (video); 100-1600 (photo) [DJI specs]
  • Max Image Size: 4000×3000 [DJI specs]
  • Photo Modes: Single shot, Burst shooting: 3/5/7 frames, Auto Exposure Bracketing (AEB): 3/5 bracketed frames at 0.7, EV Bias, Interval [DJI specs]
  • Video Recording Modes: C4K: 4096×2160 24p, 4K: 3840×2160 24/25/30p, 2.7K: 2704×1520 24/25/30p, FHD: 1920×1080 24/25/30/48/50/60/96p, HD: 1280×720 24/25/30/48/50/60/120p [DJI specs]
  • Max Video Bitrate: 60 Mbps [DJI specs]
  • Gimbal Tilt: Pitch: -90° to +30° [DJI specs]
  • Camera has same 1/2.3 inch sensor as P3/P4 [Dr Turbo]
  • FOV is smaller (78.8 degrees) [Dr Turbo]
  • Autofocus with nearest focus range of 0.5 meters [Dr Turbo]
  • Camera Cover: Leave off for best quality & on when transporting [blade strike]
  • How to set Focus: Works just like an x5. Tap area you want focused and it focuses. If you focus on something 50m out, it's pretty much set to infinity. [blade strike]
  • Streams at 1080p to phone/goggles (rather than 720p on P4) [Scott Simmie]
Flight Modes
  • Sport Mode: Allows speeds of up to 40 MPH [DJI]
  • TapFly: Direct Mavic to go wherever you want, avoiding obstacles along the way [DJI]
  • Can control Mavic with hand gestures [DJI]
  • Gesture Mode: Use gestures to have Mavic locate you, center you in the frame and take the perfect shot as Mavic’s flashing lights count down to the photo [DJI]
  • Terrain Follow Mode: Can race up a slope behind a subject while remaining at a constant height between 1 ft (0.3 m) and 33 ft (10 m) [DJI]
  • Tripod Mode: Slowing & fine-tuning Mavic’s position & angle based on controller movement inputs to allowing for precision framing & safe indoor flight [DJI]
  • ActiveTrack: Recognizes common objects (e.g. people, bicyclists, cars, boats & animals); send Mavic to follow behind, lead in front, circle above or track alongside the subject, keeping the camera focused on the subject while you concentrate on flight maneuvers [DJI]
  • ActiveTrack: As the Mavic is tracking, you can even select exactly where you want the subject in the frame [B&H]
  • Trace: Follow behind or in front of your subject, or circle it as it moves [B&H]
  • Profile: Fly alongside your subject [B&H]
  • Spotlight: Keeps camera trained on your subject while you fly almost anywhere [B&H]
  • Selfie Mode: Put the Mavic in Gesture Mode and walk in front of it. Mavic will auto detect you. Raise your arms or wave to it to make it follow you. Make a box shape with your fingers when ready to take a photo. The lights under the Mavic's front arms will start to flash, and you'll have 3 seconds before it takes a photo [B&H]
  • Tripod Mode: Caps Mavic's maximum speed at just 2.2 mph, while the control stick sensitivity of the remote controller is dulled to give you the precision for accurate framing. Great for flying indoors or in small spaces. [B&H]
  • Terrain Follow: When you're flying over changing terrain, this mode uses height information gathered by the on-board ultrasonic system & its downward-facing cameras to keep you flying at the same height above the ground even as the ground moves. Just set the height from the ground you want (from 9 to 33') [B&H]
Performance
  • FlightAutonomy can position, navigate and plan routes for Mavic, enabling it to avoid obstacles in various environments, with or without the help of satellite signals [DJI]
  • FlightAutonomy provides significant boost in working range & can cope with complex 3D environments [DJI]
  • Avoids most obstacles at speeds up to 22 MPH [DJI]
  • Remains stable in winds of up to 24 MPH [DJI]
  • Max Ascent Speed: 16.4 ft/s (5 m/s) in Sport mode [DJI specs]
  • Max Descent Speed: 9.8 ft/s (3 m/s) [DJI specs]
  • Max Speed: 40 mph (65 kph) in Sport mode without wind [DJI specs]
  • Obstacle Sensory Range: Precision measurement range: 2 ft (0.7 m) to 49 ft (15 m); Detectable range: 49 ft (15 m) to 98 ft (30 m) [DJI specs]
  • Max Altitude: 500 m above the takeoff point [blade strike]
  • VPS Range: 1 - 43 feet (0.3 - 13 m) altitude; Surface with clear pattern and adequate lighting (lux > 15) [DJI specs]
  • Once props start spinning, centrifugal force will auto unfold props into the correct position [DJI FAQ]
  • During takeoff, the Mavic’s stereo cameras record a burst of photos without you even knowing it. It then uses that imagery & GPS info to land within an inch of where it took off when you’re using an auto-land/RTH function. [Scott Simmie]
Aircraft
  • Easily carried in a purse/backpack [DJI]
  • Folding design compresses entire drone to practically size of a water bottle [DJI]
  • Four folding arms and propellers tuck neatly away against its streamlined body [DJI]
  • Can be set up & airborne in less than a minute [DJI]
  • GPS & GLONASS navigation systems [DJI]
  • Redundant sensors [DJI]
  • 24 powerful computing cores [DJI]
  • Ultra light and aerodynamic airframe [DJI]
  • Uses DJI's GEO geofencing system to help identify restricted areas, preventing flight in locations that might raise safety/security concerns [DJI]
  • Set to automatically return to its launch location if it ever loses contact with the controller or reaches critically low battery levels [DJI]
  • Precision landing feature records a burst of video with two stereo cameras every time Mavic launches, then uses both video and satellite information when it returns to land within an inch of where it took off [DJI]
  • OcuSync (new video link system) supports a range up to 4.3 miles (7 km) and live view resolutions up to 1080p [DJI]
  • New band management algorithm makes OcuSync more robust in environments with many frequencies in operation [DJI]
  • Equipped with dual-band WiFi as secondary link, allowing easy control via smartphone for close range operation or for quick downloading of content from Mavic to your device [DJI]
  • Folded Size: H 83mm x W 83mm x L 198mm [DJI specs]
  • Weight: 1.62 lbs (734 g) without gimbal cover; 1.64 lbs (743 g) with gimbal cover [DJI specs]
  • Supported Mobile Device Size: Thickness Supported:6.5-8.5mm; Max length: 160mm [DJI specs]
  • Can be powered on folded [blade strike]
  • Props designed as a single unit [Joe_DJI]
  • Arms are heavy-duty, but not metal. They snap into place when collapsed/expanded with no locking mechanism necessary. [Joe_DJI]
  • Dual compass & IMU for redundancy [B&H]
  • Folding mechanism has been tested to last at least 5,000 folds [DJI FAQ]
Remote Controller
  • Can be operated by powerful long range remote controller or with smartphone at shorter range [DJI]
  • Compact RC designed to provide ergonomic experience with optimum comfort [DJI]
  • RC can accommodate a smartphone or control Mavic on its own [DJI]
  • RC's built-in LCD screen displays essential telemetry data, while dedicated buttons for functions such as Return-to-Home and pausing during Intelligent Flight modes ensure a confident flight every single time [DJI]
  • Max Transmission Distance: FCC Compliant: 4.3 mi (7 km); CE Compliant: 2.5 mi (4 km) when unobstructed & free of interference [DJI specs]
  • Transmitter power: FCC:≤26 dBm; CE:≤20 dBm [DJI specs]
  • 4.3 mile (7 km) range when flying with remote controller [DJI FAQ]
  • 80m range & max altitude of 50m when flying with WiFi device [DJI FAQ]
  • Semi-fixed RC connector, you could change between various USB ports and lightning [Dr Turbo]
  • RC will not hold an iPad Mini, officially. You could figure out a way to do it, but not as comfortable as a mobile phone. [Dr Turbo]
  • RC only has a USB port (no HDMI port) [Tahoe Ed]
  • Run Time: About 6-7 battery packs [blade strike]
  • Charge Time: 1-2 hours [blade strike]
  • Micro USB port on the side for charging [blade strike]
  • Antennas click into each other for safe storage [Joe_DJI]
  • RCs from other DJI aircraft cannot be used to fly the Mavic [Joe_DJI]
  • Features a small, clear monochrome screen that displays modes, telemetry & other key features. [Scott Simmie]
  • Gives haptic feedback via vibration to alert pilot about important events mid-flight [RC Groups]
DJI Goggles
  • Mavic also pairs with DJI’s new immersive DJI Goggles, displaying an 85-degree view from the drone in full 1080p for a true bird’s-eye view of the world below [DJI]
  • Googles have built-in OcuSync, the goggles receive video directly from Mavic Pro in the air and not through the controller, reducing lag to a minimum [DJI]
  • DJI Goggles allows you to flick between third person view & FPV in under a second [DJI]
  • can comfortably wear your glasses while wearing the goggles and quit FPV mode instantly by flipping the mask up [DJI]
  • Designed to make flying totally immersive. Feature two 1080p LTPS displays with a wide 85° angle of view to give you a bird's eye view of the world around you. Built-in OcuSync connectivity means that it links directly to the Mavic & not through a cable or a Wi-Fi link to the controller. Connection yields delay of only 120 milliseconds. [B&H]
DJI Care Refresh
  • DJI Care Refresh is a new optional protection plan, DJI Care Refresh, is available in select countries and provides peace of mind for Mavic Pro owners [DJI]
  • Covers accidental damage to the Mavic Pro aircraft, gimbal or camera during normal use for up to 12 months [DJI]
  • For an additional charge, DJ will offer up to 2 full replacements that are new or equivalent to new [DJI]
  • Must purchase before Mavic is activated or within the first 48 hours after activation [DJI]
Other
  • Live streaming to Facebook, Periscope, or YouTube via DJI GO [DJI]
  • ND filters are coming [blade strike]
  • You could also just fly with a tablet over WiFi [blade strike]
  • Firmware updates can be installed via DJI Assistant 2 [blade strike]
  • It really wasn't designed to be a racer. Anyone that has seen or flown a racer will know this. [blade strike]
  • The aircraft is not user serviceable. It's honestly built like a Swiss watch. You always have the option to send the aircraft in for repair. If malfunction is shown in the flight logs, the repair will be covered at no cost if still under warranty. [blade strike]
Findings after flying the Mavic Pro
Camera
  • Found you need to set focus during or before take off to get the best results [blade strike]
  • On startup, the camera will usually auto focus on something on the ground. This is why you should auto focus once air born on something about 50m out. That will give you infinity. You can forget about it from that point on unless you want to later focus on a closer subject. [blade strike]
Flight Modes
  • Sport Mode: Even at these speeds, aircraft is incredibly responsive & nimble. No, it’s not on same level as tweaked-out racing drone, but it's very impressive for a consumer/prosumer personal quadcopter. [Scott Simmie]
  • ATTI Mode: There is no remote controller switch and/or other way to manually switch to ATTI mode.
General
  • The P4 & Mavic are different craft made for different users. Some will have both but this will probably have my phantoms sitting longer just do to the fact you cant take this anywhere with very little spaced used with 95% of the performance. [blade strike]
  • It does not show props as much as the P4. ONLY at very extreme angles and ONLY in sport mode. [blade strike]
  • We've had no problem with hand catching. Just grab it by the body from underneath. Ensure there is no wind to stop mid-air adjustments. [Joe_DJI]
  • Incredibly sturdy and our units here, after dozens of hours of flight time, show no signs of sloppiness or wear [Joe_DJI]
  • It's not a new Phantom; not a new Inspire. It's unlike anything DJI has produced in the past. [Scott Simmie]
Performance
  • Have flown in 15 MPH with solid footage [blade strike]
  • Handles the same wind as the P4 by my testing [blade strike]
  • A little bit of wind & piro does cause some altitude drop (about a foot or two) but it does recover. [blade strike]
  • Gives you high wind warning, but does not issue RTH unless you do or it loses contact with RC [blade strike]
  • If you are experienced with the P4, it will feel very familiar to you -- but it's even more stable [Joe_DJI]
  • The Mavic hung there like it was glued in space [Scott Simmie]
  • Noticeably quieter than the P4 [Scott Simmie]
  • Flawless, smooth, and highly responsive [Scott Simmie]
  • Lower weight makes it feel more agile/nimble [Scott Simmie]
Where to buy the Mavic Pro
The Mavic Pro can be ordered from DJI, Amazon, Apple, Best Buy, and other authorized DJI dealers.
Review Sources
The following reviews were used to compile the information above:
DJI Mavic Specs: www.dji.com/mavic/info#specs
DJI Mavic FAQ: http://www.dji.com/mavic/info#faq
RC Groups: www.rcgroups.com/forums/showthread.php?t=2747762
And here's some tutorials to go with the meta-review :)
All good stuff meta ,bet that took awhile to type !
Reactions: dirkclod
A very comprehensive view of all the features....makes for interesting reading. Thank you for taking the trouble to put all this together.
Reactions: msinger
  • You can also use the micro on the side for video out [blade strike]
Welp, time to invest in a microUSB-to-HDMI cable. Would definitely be neat to have a larger monitor next to you for displaying FPV to a crowd.
Mavic Pro features
Battery
  • Max Flight Time: 27 minutes (0 wind at a consistent 15.5 MPH) [DJI specs]
  • Average Flight Time: 21 minutes (in normal flight with 15% remaining battery level) [DJI specs]
  • The 3830 mAh LiPo battery charged in about an hour [Scott Simmie]
  • Charger includes two USB ports -- handy for charging remote controller at the same time [Scott Simmie]
  • Could also charge it with charging hub plus a Phantom 4 100W adaptor (takes 130 minutes to charge four batteries from 15% to 100%) [DJI Propulsion (Dr Turbo)]
Camera
  • Smallest-ever 3-axis gimbal for shake-free photos and video [DJI]
  • Autofocus camera features a minimum focusing distance of just 19 in (0.5 m) and can be flipped 90 degrees to portrait mode for vertical selfies and video[DJI]
  • 12-megapixel camera with Adobe DNG RAW support has been expertly tuned for aerial images[DJI]
  • Camera sensor: 1/2.3” (CMOS), Effective pixels:12.35 M (Total pixels:12.71M) [DJI specs]
  • Camera lens: FOV 78.8° 28 mm (35 mm format equivalent) f/2.2; Distortion < 1.5% Focus from 0.5 m to ∞ [DJI specs]
  • Shutter speed: 8s -1/8000s [DJI specs]
  • ISO range: 100-3200 (video); 100-1600 (photo) [DJI specs]
  • Camera has same 1/2.3 inch sensor, same frame as P3/P4/Inspire X3 [DJI Propulsion (Dr Turbo)]
  • The FOV of Mavic is smaller, at 78.8 degrees. It is an Auto Focus camera that has a nearest focus range of 0.5 meter, and can rotate 90 degrees to portrait mode. All in all, good for selfie. [DJI Propulsion (Dr Turbo)]
  • Camera Cover: It is to protect the camera for transport. Easily removable. Yes you can fly with it but it is not recommended. [Tahoe Ed]
  • Camera Cover: for best quality this needs to be left off. now if your just flying around and not taking footage then you could leave it on for protection. I use mine for transport [blade strike]
  • Has Focus and 2X optical zoom [Tahoe Ed]
  • How to set Focus: It works just like an x5. Tap it on an area that you want focused and it focuses. If you focus on something 50m out it's pretty much set to infinity. [blade strike]
  • Streams at 1080p to your phone or goggles, rather than the 720p of the Phantom 4 [Scott Simmie]
  • You can even flip the camera 90-degrees for portrait oriented shots, just like you do with your phone [B&H]
Flight Modes
  • FlightAutonomy makes it possible to control the drone completely with just hand gestures [DJI]
  • Gesture Mode: you can use gestures to have Mavic Pro locate you, center you in the frame and take the perfect shot as Mavic Pro’s flashing lights count down to the photo [DJI]
  • Terrain Follow Mode: means that you can race up a slope behind a subject while remaining at a constant height between 1 ft (0.3 m) and 33 ft (10 m) [DJI]
  • Tripod Mode: designed for indoor use, slowing and fine-tuning Mavic Pro’s position and angle based on controller movement inputs to allowing for precision framing and safe indoor flight [DJI]
  • Updated version of DJI’s ActiveTrack recognizes common subjects such as people, bicyclists, cars, boats and animals, which then sends Mavic Pro to follow behind, lead in front, circle above or track alongside the subject, keeping the camera focused on the subject while you concentrate on flight maneuvers [DJI]
  • It can distinguish between people, cars, bicycles, and even animals. And it can track each of them, in a variety of modes: It can follow from behind, lead from the front, track alongside – even orbit the moving subject while keeping the camera locked on. [Scott Simmie]
  • it can follow someone up a slope while maintaining a pre-programmed altitude above ground level (think following a mountain biker or hiker as they ascend). [Scott Simmie]
  • Spotlight: Keep the camera trained on your subject while you fly almost anywhere [B&H]
  • Selfie mode: All you need to do is put the Mavic in Gesture Mode and walk in front of it. The Mavic will automatically detect you. Raise your arms or wave to it to make it follow you, and when you're ready for your photo, make a box shape with your fingers. The lights under the Mavic's front arms will start to flash, and you will have three seconds to strike your pose before it takes a photo [B&H]
  • Tripod Mode caps the Mavic's maximum speed at just 2.2 mph, while the control stick sensitivity of the remote controller is dulled to give you the precision you need for accurate framing. It is also great for flying indoors or other small spaces where the Mavic's normal speed may make it more challenging to fly [B&H]
  • Terrain Follow: When you are flying over changing terrain, like following bikers riding uphill, the Mavic's Terrain Follow function uses height information gathered by the on-board ultrasonic system, and its downward-facing cameras to keep you flying at the same height above the ground even as the ground moves. Just set the height from the ground you want — from 9 to 33' — and focus on getting the right shot [B&H]
Performance
  • FlightAutonomy can position, navigate and plan routes for Mavic Pro, enabling it to avoid obstacles in various environments, with or without the help of satellite signals [DJI]
  • FlightAutonomy provides a significant boost in working range and can cope with complex 3D environments [DJI]
  • Will avoid most obstacles at speeds up to 22 MPH [DJI]
  • Will remain stable in winds of up to 24 MPH [DJI]
  • Max speed: 40 mph (65 kph) in Sport mode without wind [DJI specs]
  • During takeoff, the Mavic Pro’s stereo cameras record a burst of photos without you even knowing it. It then uses that imagery and GPS information to land within an inch of where it took off when you’re using an auto-land/RTH function. [Scott Simmie]
Aircraft
  • DJI’s first personal drone designed to be taken just about anywhere [DJI]
  • Easily carried in a purse or backpack [DJI]
  • Folding design compresses the entire drone to practically the size of a water bottle [DJI]
  • Whole system can be set up and airborne in less than a minute [DJI]
  • GPS and GLONASS navigation systems [DJI]
  • Uses DJI's GEO geofencing system to help identify restricted areas, preventing flight in locations that might raise safety or security concerns [DJI]
  • Precision Landing feature records a burst of video with two stereo cameras every time Mavic Pro launches, then uses both video and satellite information when it returns to land within an inch of where it took off [DJI]
  • Equipped with dual-band WiFi as a secondary link, allowing easy control via your smartphone for close range operation or for quick downloading of content from Mavic Pro straight to your device [DJI]
  • Folded size: H 83mm x W 83mm x L 198mm [DJI specs]
  • Weight: 1.62 lbs (734 g) (exclude gimbal cover); 1.64 lbs (743 g) (include gimbal cover) [DJI specs]
  • The props are designed as a single unit [Joe_DJI]
  • The arms are heavy-duty, but not metal. They snap into place when collapsed or expanded with no locking mechanism necessary. [Joe_DJI]
  • Dual compass and IMU for redundancy [B&H]
Remote Controller
  • Can be operated by the powerful long range remote controller, or simply by your smartphone at shorter range [DJI]
  • Compact remote controller has been designed to provide a fully ergonomic experience with optimum comfort [DJI]
  • Remote controller can accommodate a smartphone or control Mavic Pro on its own [DJI]
  • Remote controller's built-in LCD screen displays essential telemetry data, while dedicated buttons for functions such as Return-to-Home and pausing during Intelligent Flight modes ensure a confident flight every single time [DJI]
  • Max Transmission Distance: FCC Compliant: 4.3 mi (7 km); CE Compliant: 2.5 mi (4 km) (Unobstructed, free of interference) [DJI specs]
  • 4.3 mile (7 km) range [DJI]
  • Semi-fixed RC connector, you could change between various USB ports and lightning [DJI Propulsion (Dr Turbo)]
  • Remote controller will not hold an iPad mini, officially. You could figure out a way to do it, but not as comfortable as a mobile phone. [DJI Propulsion (Dr Turbo)]
  • Remote controller only has a USB port (no HDMI port) [Tahoe Ed]
  • Run time: About 6-7 packs [blade strike]
  • Charge time:1-2 hours [blade strike]
  • Micro USB port is on the side for charging [blade strike]
  • The antennas click into each other for safer storage. [Joe_DJI]
  • Remote controllers from other DJI aircraft cannot be used to fly the Mavic [Joe_DJI]
  • The remote features a small but clear monochrome screen that displays modes, telemetry and other key features. [Scott Simmie]
DJI Goggles
  • Mavic Pro also pairs with DJI’s new immersive DJI Goggles, displaying an 85-degree view from the drone in full 1080p for a true bird’s-eye view of the world below [DJI]
  • DJI Goggles allows you to flick between third person view and FPV in under a second [DJI]
  • Designed to make flying totally immersive. The feature two 1080p LTPS displays with a wide 85° angle of view to give you a bird's eye view of the world around you. Built-in OcuSync connectivity means that it links directly to the Mavic and not through a cable or a Wi-Fi link to the controller. This seamless connection yields a delay of only 120 milliseconds [B&H]
DJI Care Refresh
  • for an additional charge will offer up to two full replacements that are new or equivalent to new [DJI]
Other
  • Live streaming to Facebook Live, Periscope and YouTube through the DJI GO app [DJI]
Camera
  • I have found is that you need to set focus during or before take off to get the best results [blade strike]
Flight Modes
  • Sport Mode: Even at these speeds, the craft is incredibly responsive and nimble. No, it’s not on the same level as a tweaked-out racing drone, but it is very impressive for a consumer/prosumer personal quadcopter. [Scott Simmie]
General
  • The P4 and Mavic are different craft made for different users. Some will have both but this will probably have my phantoms sitting longer just do to the fact you cant take this anywhere with very little spaced used with 95% of the performance [blade strike]
  • The mavic does not show props as much as the p4.. ONLY at very extreme angles and ONLY in sports mode [blade strike]
  • Incredibly sturdy and our units here, after dozens of hours of flight time, show no signs of sloppiness or wear. [Joe_DJI]
  • It is not a new Phantom; not a new Inspire. It is, in fact, unlike anything DJI has produced in the past. [Scott Simmie]
Performance
  • I have flown in 15mph with solid footage [blade strike]
  • It handles the same wind as the P4 by my testing [blade strike]
  • A little bit of wind and piro does cause some altitude drop (about a foot or two) but it does recover. [blade strike]
  • Does give you high wind warning but does not issue rth unless you do or it loses contact with RC [blade strike]
  • If you are experienced with the Phantom 4 it will feel very familiar to you, but it is even more stable. It's hard to describe accurately the feeling of flying it, but the work our engineers put into it really shows. [Joe_DJI]
  • It was also noticeably quieter than the Phantom 4, therefore much less obtrusive for people who don’t like the buzzing of drones. This is a major difference. [Scott Simmie]
  • The lower weight of this machine makes it feel more agile and nimble [Scott Simmie]
The Mavic Pro can be preordered from DJI, Amazon, Apple, and other authorized DJI dealers.
Review Sources
DJI: dji.com
B&H: www.bhphotovideo.com
Know of a good review that's not listed above? Please comment below so I can include it in this meta-review.
Expect most of these features on the P5.
"Has Focus and 2X optical zoom". I believe it is 2x digital zoom.
I cannot find a mention of this anywhere else, so I'll strike it from this list for now. It seems it would have been listed in DJI's specs if it really had an optical zoom.
What P5? In all seriousness, are we sure there'll be one? Seems to me the Phantom was a cheaper and more accessible drone than the Inspire. A design that spawned around 4 years ago with the P1.
Here we have the Mavic, which is even cheaper and you can bring it with you far easier. From the looks of it it will handle impact/crashes better too but we can't know for sure.
If you want top quality, you go Inspire X5. If you want portability, you go Mavic. When they come up with a better camera for the Phantom, that camera will be able to fit the Mavic as well.
What place is there for Phantom?
That's a great summary, thank you msinger! Can't wait for delivery in October :)
Reactions: Peio64270
I heard a DJI employee mention that the controller has a vibration feature to notify the user that there is some important info on screen to pay attention to.
Very nice. I see that mentioned here.
Reactions: Mark The Droner
The same reason they are going to release the Inspire 2. It's a different class of aircraft.
Yes it most certainly is. It's more cumbersome.
I don't want to come off as ignorant :) I just can't see the reason for a new Phantom now that they have this new form factor. Unless the Phantom X concept is real but even then.. What is there to put on a Phantom that you can't put on the Mavic? I'm not asking you directly, more to myself. I just can't think of anything.
Look the quality of the Mavic
Obviously the Phantom will stick around.
ODIN Reviews
