DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2014-11-12 6:42:26 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3840448 Bytes = 3.7 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-Kernel-1.1-rc1
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@u-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #5 PREEMPT Wed Nov 12 14:42:20 CST 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44640KB available (3472K code, 439K data, 112K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.030000] EVM: HD imager video input
[ 0.030000] sw gpio29 value:0
[ 0.100000] bio: create slab <bio-0> at 0
[ 0.100000] DM365 IPIPE initialized in Continuous mode
[ 0.110000] usbcore: registered new interface driver usbfs
[ 0.110000] usbcore: registered new interface driver hub
[ 0.110000] usbcore: registered new device driver usb
[ 0.110000] vpss vpss: dm365_vpss vpss probed
[ 0.110000] vpss vpss: dm365_vpss vpss probe success
[ 0.110000] dm365_afew_hw_init
[ 0.120000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.120000] VPBE Encoder Initialized
[ 0.120000] cfg80211: Using static regulatory domain info
[ 0.120000] cfg80211: Regulatory domain: US
[ 0.120000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.120000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.120000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.120000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.120000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.120000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.120000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.120000] cfg80211: Calling CRDA for country: US
[ 0.120000] LogicPD encoder initialized
[ 0.120000] Switching to clocksource timer0_1
[ 0.130000] musb_hdrc: version 6.0, pio, host, debug=0
[ 0.150000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[ 0.150000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.150000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.150000] usb usb1: configuration #1 chosen from 1 choice
[ 0.150000] hub 1-0:1.0: USB hub found
[ 0.150000] hub 1-0:1.0: 1 port detected
[ 0.150000] NET: Registered protocol family 2
[ 0.150000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.150000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.150000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.150000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.150000] TCP reno registered
[ 0.150000] NET: Registered protocol family 1
[ 0.150000] RPC: Registered udp transport module.
[ 0.150000] RPC: Registered tcp transport module.
[ 0.150000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.160000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.160000] msgmni has been set to 87
[ 0.170000] alg: No test for stdrng (krng)
[ 0.170000] io scheduler noop registered (default)
[ 0.210000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
[ 0.290000] Console: switching to colour frame buffer device 240x67
[ 0.380000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuffer size 8100KB
[ 0.380000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.380000] davincifb davincifb.0: dm_osd1_fb: 720x576x4@0,0 with framebuffer size 810KB
[ 0.390000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.450000] DM365 IPIPEIF probed
[ 0.450000] imp serializer initialized
[ 0.450000] davinci_previewer initialized
[ 0.450000] davinci_resizer initialized
[ 0.450000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.460000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.920000] console [ttyS0] enabled
[ 0.920000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.930000] brd: module loaded
[ 0.940000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.950000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.960000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.970000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.970000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 0.980000] 0x000000000000-0x000008000000 : "all"
[ 0.990000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 1.000000] UBI: attaching mtd2 to ubi0
[ 1.000000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.010000] UBI: logical eraseblock size: 126976 bytes
[ 1.020000] UBI: smallest flash I/O unit: 2048
[ 1.020000] UBI: sub-page size: 512
[ 1.020000] UBI: VID header offset: 2048 (aligned 2048)
[ 1.030000] UBI: data offset: 4096
[ 1.510000] UBI: attached mtd2 to ubi0
[ 1.520000] UBI: MTD device name: "filesystem"
[ 1.520000] UBI: MTD device size: 113 MiB
[ 1.530000] UBI: number of good PEBs: 904
[ 1.530000] UBI: number of bad PEBs: 0
[ 1.540000] UBI: max. allowed volumes: 128
[ 1.540000] UBI: wear-leveling threshold: 4096
[ 1.550000] UBI: number of internal volumes: 1
[ 1.550000] UBI: number of user volumes: 1
[ 1.550000] UBI: available PEBs: 0
[ 1.560000] UBI: total number of reserved PEBs: 904
[ 1.560000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.570000] UBI: max/mean erase counter: 60/1
[ 1.570000] UBI: image sequence number: 1231824996
[ 1.580000] UBI: background thread "ubi_bgt0d" started, PID 313
[ 1.620000] UBI: scrubbed PEB 168 (LEB 2147479551:0), data moved to PEB 900
[ 1.650000] UBI: scrubbed PEB 169 (LEB 2147479551:1), data moved to PEB 899
[ 1.660000] console [netcon0] enabled
[ 1.670000] netconsole: network logging started
[ 1.670000] i2c /dev entries driver
[ 1.680000] Linux video capture interface: v2.00
[ 1.680000] vpfe_init
[ 1.690000] vpfe-capture: vpss clock vpss_master enabled
[ 1.690000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.700000] vpfe-capture vpfe-capture: video device registered
[ 1.710000] EVM: switch to tvp5151 cvbs video input
[ 1.710000] vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
[ 1.720000] EVM: switch to it6604 hdmi video input
[ 1.730000] vpfe-capture vpfe-capture: v4l2 sub device cat6023 registered
[ 1.740000] vpfe_register_ccdc_device: DM365 ISIF
[ 1.750000] DM365 ISIF is registered with vpfe.
[ 1.750000] Trying to register davinci display video device.
[ 1.760000] layer=c106c400,layer->video_dev=c106c564
[ 1.770000] Trying to register davinci display video device.
[ 1.770000] layer=c106c800,layer->video_dev=c106c964
[ 1.780000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[ 1.780000] watchdog watchdog: heartbeat 1 sec
[ 1.790000] TCP cubic registered
[ 1.790000] NET: Registered protocol family 17
[ 1.800000] lib80211: common routines for IEEE802.11 drivers
[ 2.440000] encrypt device:at88 found
[ 2.480000] Clocks: disable unused mmcsd0
[ 2.480000] Clocks: disable unused mmcsd1
[ 2.480000] Clocks: disable unused spi0
[ 2.480000] Clocks: disable unused spi1
[ 2.480000] Clocks: disable unused spi2
[ 2.480000] Clocks: disable unused spi3
[ 2.480000] Clocks: disable unused spi4
[ 2.480000] Clocks: disable unused pwm0
[ 2.480000] Clocks: disable unused pwm1
[ 2.480000] Clocks: disable unused pwm2
[ 2.480000] Clocks: disable unused pwm3
[ 2.480000] Clocks: disable unused timer1
[ 2.480000] Clocks: disable unused timer3
[ 2.480000] Clocks: disable unused emac
[ 2.480000] Clocks: disable unused voice_codec
[ 2.480000] Clocks: disable unused asp0
[ 2.480000] Clocks: disable unused rto
[ 2.480000] Clocks: disable unused mjcp
[ 2.550000] nnnn===0
[ 2.550000] davinci_emac_probe: using random MAC addr: ca:20:be:26:b0:40
[ 2.560000] emac-mii: probed
[ 2.600000] UBIFS: recovery needed
[ 2.660000] UBIFS: recovery completed
[ 2.670000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.670000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 2.680000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 2.690000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.700000] UBIFS: default compressor: lzo
[ 2.700000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.710000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 2.710000] Freeing init memory: 112K
Filesystem Product Vesion : DJI-Filesystem-1.0-rc2
Runing /etc/init.d/rcS
[ 3.110000] UBI: scrubbed PEB 165 (LEB 0:163), data moved to PEB 514
[ 4.600000] CMEMK module: built on Jan 14 2014 at 19:23:51
[ 4.620000] Reference Linux version 2.6.32
[ 4.620000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 4.640000] allocated heap buffer 0xc7000000 of size 0x15e2000
[ 4.670000] heap fallback enabled - will try heap if pool buffer is not available
[ 4.670000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 4.690000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 4.690000] cmemk initialized
[ 4.720000] IRQK module: built on Jan 14 2014 at 19:23:57
[ 4.740000] Reference Linux version 2.6.32
[ 4.740000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 4.760000] irqk initialized
[ 4.810000] EDMAK module: built on Jan 14 2014 at 19:24:08
[ 4.830000] Reference Linux version 2.6.32
[ 4.830000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
sulogin: no password entry for root
login[421]: root login on 'ttyS0'
#Process /etc/profile...
root@Dji-Pro:~#
Switch V00.02.00.00(Feb 3 2015 11:02:17).
usb or cvbs output switch:0 cvbs
hdmi2tv V00.01.01.00(Feb 3 2015 11:02:17).
calling cmem utilities for allocati[ 5.300000] davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
ng frame buffers[ 5.310000] davinci_previewer davinci_previewer.2: ipipe_set_preview_config
Allocating cap[ 5.320000] davinci_previewer davinci_previewer.2: ipipe_set_preview_config
ture buffers :buf size = 4149248[ 5.330000] vpfe-capture vpfe-capture: IPIPE Chained
Got 0x401ae00[ 5.330000] vpfe-capture vpfe-capture: Resizer present
0 from CMEM, phy[ 5.340000] EVM: switch to it6604 hdmi video input
= 0x86d97000
G[ 5.350000] hdmi is not online
ot 0x405a3000 from CMEM, phy = 0x869a2000
Allocating display buffers :buf size = 4149248
Got 0x40998000 from CMEM, phy = 0x865ad000
Got 0x40d8d000 from CMEM, phy = 0x861b8000
opening resize device
Successfully set mode to continuous in resizer
default configuration setting in Resizer successfull
Resizer initialized
Operating mode changed successfully to continuous in previewerSetting default configuration in previewer
default configuration setting in previewer successfull
setting data format
Detecting if driver supports Hdmi_yuv
input.name = Composite
input.name = S-Video
input.name = Hdmi_yuv
InitDevice:ioctl:VIDIOC_G_INPUT, selected input Hdmi_yuv
[ 7.350000] hdmi is not online
[ 9.350000] hdmi is not online
[ 11.360000] hdmi is not online
[ 13.360000] hdmi is not online
[ 15.360000] hdmi is not online
[ 17.370000] hdmi is not online
[ 19.370000] hdmi is not online
[ 21.380000] hdmi is not online
[ 23.380000] hdmi is not online
[ 25.380000] hdmi is not online
[ 27.390000] hdmi is not online
[ 29.390000] hdmi is not online
[ 31.390000] hdmi is not online
[ 33.400000] hdmi is not online
[ 35.400000] hdmi is not online
[ 37.400000] hdmi is not online
[ 39.410000] hdmi is not online
[ 41.410000] hdmi is not online
[ 43.410000] hdmi is not online
[ 45.420000] hdmi is not online
[ 47.420000] hdmi is not online
[ 49.420000] hdmi is not online
[ 51.430000] hdmi is not online
[ 53.430000] hdmi is not online
[ 55.430000] hdmi is not online
[ 57.440000] hdmi is not online
[ 59.440000] hdmi is not online
[ 61.440000] hdmi is not online
[ 63.450000] hdmi is not online
[ 65.450000] hdmi is not online
[ 67.450000] hdmi is not online
[ 69.460000] hdmi is not online
[ 71.460000] hdmi is not online
[ 73.470000] hdmi is not online
[ 75.470000] hdmi is not online
[ 77.470000] hdmi is not online
[ 79.480000] hdmi is not online
[ 81.480000] hdmi is not online
[ 83.480000] hdmi is not online
[ 85.490000] hdmi is not online
[ 87.490000] hdmi is not online
[ 89.490000] hdmi is not online
[ 91.500000] hdmi is not online
[ 93.500000] hdmi is not online
[ 95.500000] hdmi is not online
[ 97.510000] hdmi is not online
[ 99.510000] hdmi is not online
