Loading from nand0, offset 0xa80000
Image Name: Linux-2.6.32.17-davinci1
Created: 2013-07-23 3:12:28 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2118348 Bytes = 2 MiB
Load Address: 80008000
Entry Point: 80008000
DM36x EVM # bootm 80700000
## Booting kernel from Legacy Image at 80700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux............................................................. ............................................................................. do ne, booting the kernel.
Linux version 2.6.32.17-davinci1 (root@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #38 PREEMPT Mon Jul 22 20:12:25 PDT 2013
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DM36x EVM
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 24576
free_area_init_node: node 0, pgdat c043a3e0, node_mem_map c046e000
DMA zone: 192 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 24384 pages, LIFO batch:3
DaVinci dm36x_rev1.2 variant 0x8
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 24384
Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davin cifb:vid0=OFF:vid1=OFF
sd0=480x272x16,4050K mem=96MB davinci_enc_mngr.ch0_outpu t=LCD davinci_enc_mngr.ch0_mode=480x272 loglevel=8 root=/dev/mtdblock2 rootfstyp e=cramfs ip=192.168.1.10:192.168.1.5:192.168.2.2:255.255.255.0::eth0
ff
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 96MB = 96MB total
Memory: 92840KB available (3976K code, 377K data, 140K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 147.28 BogoMIPS (lpj=245248)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 8 gpio irqs
NET: Registered protocol family 16
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x5c/0x12c()
autorequest GPIO-20
Modules linked in:
Backtrace:
[<c002f5ec>] (dump_backtrace+0x0/0x114) from [<c0316d98>] (dump_stack+0x18/0x1c)
r7:c4023f00 r6:c01a71b8 r5:c03cab0d r4:00000065
[<c0316d80>] (dump_stack+0x0/0x1c) from [<c0040b78>] (warn_slowpath_common+0x50/ 0x68)
[<c0040b28>] (warn_slowpath_common+0x0/0x68) from [<c0040bdc>] (warn_slowpath_fm t+0x30/0x38)
r7:00000000 r6:c043b228 r5:c045a590 r4:c043b228
[<c0040bac>] (warn_slowpath_fmt+0x0/0x38) from [<c01a71b8>] (gpio_ensure_request ed+0x5c/0x12c)
r3:00000014 r2:c03cab24
[<c01a715c>] (gpio_ensure_requested+0x0/0x12c) from [<c01a730c>] (gpio_direction _output+0x84/0x148)
r9:00000000 r8:c045a590 r7:00000001 r6:00000014 r5:40000013
r4:c043b228
[<c01a7288>] (gpio_direction_output+0x0/0x148) from [<c000ebf0>] (dm365_evm_init +0x24/0x294)
[<c000ebcc>] (dm365_evm_init+0x0/0x294) from [<c000b518>] (customize_machine+0x2 0/0x2c)
r8:00000000 r7:00000001 r6:c000b4f8 r5:00000000 r4:c0022be0
[<c000b4f8>] (customize_machine+0x0/0x2c) from [<c002b3d4>] (do_one_initcall+0x6 4/0x1c4)
[<c002b370>] (do_one_initcall+0x0/0x1c4) from [<c0008474>] (kernel_init+0x9c/0x1 18)
r7:00000000 r6:00000000 r5:00000000 r4:c0022be0
[<c00083d8>] (kernel_init+0x0/0x118) from [<c00440f8>] (do_exit+0x0/0x668)
r5:00000000 r4:00000000
---[ end trace 1b75b31a2719ed1c ]---
davinci_serial_init:97: failed to get UART2 clock
EVM: tvp5146 SD video input
bio: create slab <bio-0> at 0
DM365 IPIPE initialized in Continuous mode
SCSI subsystem initialized
vpss vpss: dm365_vpss vpss probed
vpss vpss: dm365_vpss vpss probe success
dm365_afew_hw_init
ch0 default output "LCD", mode "480x272"
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
<logicpd_encoder_setoutput>
Start of logicpd_encoder_setmode..
</logicpd_encoder_setoutput>
LogicPD Encoder initialized
<logicpd_encoder_enumoutput>
</logicpd_encoder_enumoutput>
<logicpd_encoder_getoutput>
</logicpd_encoder_getoutput>
<logicpd_encoder_getmode>
</logicpd_encoder_getmode>
LogicPD encoder initialized
Switching to clocksource timer0_1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 181
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
Console: switching to colour frame buffer device 60x34
davincifb davincifb.0: dm_osd0_fb: 480x272x16@0,0 with framebuffer size 4050KB
davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 382KB
davincifb davincifb.0: dm_osd1_fb: 480x272x4@0,0 with framebuffer size 255KB
davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 382KB
DM365 IPIPEIF probed
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
console [ttyS0] enabled
brd: module loaded
at24 1-0050: 32768 byte 24c256 EEPROM (writable)
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit )
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x000001240000
Creating 4 MTD partitions on "davinci_nand.0":
0x000000000000-0x000000640000 : "bootloader"
0x000000640000-0x000000680000 : "params"
0x000000680000-0x000001280000 : "kernel"
0x000001280000-0x000008000000 : "filesystem2"
davinci_nand davinci_nand.0: controller rev. 2.3
spi_davinci spi_davinci.0: DaVinci SPI driver in EDMA mode
Using RX channel = 17 , TX channel = 16 and event queue = 3
at25 spi0.0: 8 KByte at25640 eeprom, pagesize 32
spi_davinci spi_davinci.0: Controller at 0xfec66000
console [netcon0] enabled
netconsole: network logging started
mice: PS/2 mouse device common for all mice
tsc2004: probe of 1-0000 failed with error -121
i2c /dev entries driver
Linux video capture interface: v2.00
ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
ths7303 1-002c: ths7303 write failed
ths7303: probe of 1-002c failed with error -121
vpfe_init
vpfe-capture: vpss clock vpss_master enabled
vpfe-capture vpfe-capture: v4l2 device registered
vpfe-capture vpfe-capture: video device registered
EVM: switch to tvp5146 SD video input
tvp514x 1-005d: tvp514x 1-005d decoder driver registered !!
vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered
EVM: switch to <NULL> video input
vpfe-capture vpfe-capture: v4l2 sub device tvp7002 register fails
EVM: switch to ▒=▒ video input
ths7353 1-002e: chip found @ 0x5c (DaVinci I2C adapter)
ths7353 1-002e: No platform data!!
ths7353 1-002e: ths7353 write failed
ths7353: probe of 1-002e failed with error -121
vpfe-capture vpfe-capture: v4l2 sub device ths7353 register fails
vpfe-capture vpfe-capture: v4l2 sub device cat6023 register fails
vpfe_register_ccdc_device: DM365 ISIF
DM365 ISIF is registered with vpfe.
af major#: 252, minor# 0
AF Driver initialized
aew major#: 251, minor# 0
AEW Driver initialized
<davinci_display_init>
Trying to register davinci display video device.
layer=c4150c00,layer->video_dev=c4150d70
layer=c4151000,layer->video_dev=c4151170
davinci_init
aVinci V4L2 Display Driver V1.0 loaded
</davinci_init>
watchdog watchdog: heartbeat 60 sec
Advanced Linux Sound Architecture Driver Version 1.0.21.
No device for DAI tlv320aic3x
No device for DAI davinci-i2s
asoc: tlv320aic3x <-> davinci-i2s mapping ok
ALSA device list:
#0: DaVinci EVM (tlv320aic3x)
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
Clocks: disable unused mmcsd0
Clocks: disable unused mmcsd1
Clocks: disable unused spi1
Clocks: disable unused spi2
Clocks: disable unused spi3
Clocks: disable unused spi4
Clocks: disable unused pwm0
Clocks: disable unused pwm1
Clocks: disable unused pwm2
Clocks: disable unused pwm3
Clocks: disable unused timer1
Clocks: disable unused timer3
Clocks: disable unused usb
Clocks: disable unused emac
Clocks: disable unused voice_codec
Clocks: disable unused rto
Clocks: disable unused mjcp
nnnn===0
davinci_emac_probe: using random MAC addr: 8e:0b:38:7a:ac:ec
emac-mii: probed
IP-Config: Gateway not on directly connected network.
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
Freeing init memory: 140K
Filesystem Product Vesion : DJI-Filesystem-1.0-rc2
Runing /etc/init.d/rcS
mount: mounting usbfs on /proc/bus/usb/ failed: No such file or directory
mount: mounting usbfs on /dev/bus/usb/ failed: No such device
cmemk: disagrees about version of symbol module_layout
insmod: can't insert '/opt/dji/modules/dsp/cmemk.ko': invalid module format
irqk: disagrees about version of symbol module_layout
insmod: can't insert '/opt/dji/modules/dsp/irqk.ko': invalid module format
edmak: disagrees about version of symbol module_layout
insmod: can't insert '/opt/dji/modules/dsp/edmak.ko': invalid module format
dm365mmap: disagrees about version of symbol module_layout
insmod: can't insert '/opt/dji/modules/dsp/dm365mmap.ko': invalid module format
BusyBox v1.21.1 (2013-11-14 14:07:22 CST) multi-call binary.
Usage: mknod [-m MODE] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
-m MODE Creation mode (default a=rw)
TYPE:
b Block device
c or u Character device
p Named pipe (MAJOR and MINOR are ignored)
exfat: disagrees about version of symbol module_layout
insmod: can't insert '/opt/dji/modules/exfat.ko': invalid module format
open /dev/dm365-gpio fail!
/opt/dji/etc/boot.sh: line 10: settime: not found
Now you can fix ****.
sulogin: no password entry for root
login[1039]: root login on 'ttyS0'
#Process /etc/profile...
root@Dji-Pro:~#
