Of course you should firmly plug the 2 pcb before to power it on for flashing.Hello.
These are the photos of my weldings...
I read the whole topic, and I did the procedure, but unfortunately it does not leave the bootme ...
the log I sent above is created with the bsel and 3.3v in short or open ...
Hi all,
For those of you with Phantom 2 Vision+ Plus quads that are suffering the blank screen in app issue - no FPV, but good telemetry data. I've successfully revived my wifi module using info from this thread (big thanks to Gaucho, rmhome, andrew_by and others).
I packaged it up into this tutorial: DJI Phantom 2 Vision+ Plus Blank Screen Corrupt NAND fix
I hope it helps some people revive their wifi modules too. Good luck and feedback on my tutorial is welcome.
Gret work okstuv!
Can you tell me how to connect the power with this converter? Should I let the jumper to 3.3v and connect another cable to the 5v output?
Did you tried to hit ctrl+c and relaunch the flash command?First of all i want to say thank you for this amazing job Goucho! Thanks a lot for this solution!
My problem is ground unit.
Works perfect for a while, after battery was discharged for about a month, as a result bye bye video signal and welcome black screen...
So, for now i solder serial to the board... everything looks fine... but...
When i power on LB with BSEL and 3.3v not jumped everything stops on the message "Starting NAND Copy..." no kernel... nothing...
When i power on LB with BSEL and 3.3v jumped, everything is stop on the "Waiting for SENDING sequence"
I try to use another FTDI adapter and another PC... but result is same...
Any solutions? What else i can try?
Thanks!
What is your product model? Which part? You can ESC the boot, then dump the memory. I wrote how to do some posts ago. Then we can compare memory location on a working unit of the same typehi,
after flash and remove jumper, in teraterm I have:
DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Dji-Pro #
I must replace the board????
No need for power on the adapter. Power comes from usb. Jumper seems to be ok. Remove the 5v wire.Gret work okstuv!
Moreover I see that bootme is printed with errors in the ascii characters. Welding are good? Are you sure it is a 3.3v uart adapter with jumper properly set?
