DJI-Vision Android App - Download APK?
Laguna Hills, Orange county, CA 92653
I ordered the Phantom 2 Vision yesterday, and went to get the DJI-Vision app
from the Google Play Store for my Vizio Android Tablet VTAB1008 (v3.2.1),
but it says that my device is not acceptable. No reason given.
In the DJI Wiki I find that Android 4 or better is "required", and that
the Samsung Galaxy S3, S4, Note 2, or Note 3 are suitable, and other
similar devices would be accepted. So, maybe I have a "suitable' device?
I try my Kyocera eVent (Android 4.0.4) and ...
it is not acceptable, and no clue to what is accepted.
One member on this forum said that he had similar problems, and
that he was able to download the APK file directly from DJI, and it
worked fine on his "unacceptable" smartphone.
I found the APK to download here: http://m.dji.net/djivision
The latest version, as of 2 Jan 2014, is 1.0.37 for DJI-Vision.
Cheers, Gary
Pe haps a list of Android devices that do work with the DJI-Vision App:
Supposed to work:
1. Samsung Galaxy S3 and S4
2. Samsung Galaxy Note 2 and Note 3
Verified by members to work:
1. HTC One (Android 4.3)
2. Nexus 7
3. Nexus 5 (running kit kat)
4. Nexus 4 (Kitkat)
5. ZTE Warp Sequent (running Android 4.1.2)
Play Store rejects:
1. Kyocera eVent (*)
2. Vizio VTAB1008 8" tablet (Android 3.2.1)
3. Samsung Galaxy Tab 2 7" Tablet (*)
4. Kindle fire hd (*)
(*) Rejected, but work with the APK from: http://m.dji.net/djivision
1. Kyocera eVent (runs, but have not flown the P2V yet)
2. Samsung Galaxy Tab 2 7" Tablet (not flown yet)
3. Kindle fire hd (reported to work with ?? what software)
4.
garygid.
You can add to the "Verified to work" a: HTC One (Android version 4.3) as I'm using it with my PV
Here is a download link to the .apk file (mods. please remove if it's not okay to post this link)
http://www.droidbin.com/p18bs3p0c31qora2r17n17p06u61
QR link to file:
To install you need to set "allow installation from unknown sources" in your android device.
How well would the Samsung Galaxy Tab 2 7" Tablet with 8GB Memory work?
1GB ram, 1024 x 600 screen, can add 32GB mini-SD card, and about $129 at Walmart.
Apparently it will display HD material (Although not in full Hi-Res).
It has WiFi (and bluetooth), but I do not know about sufficient motion
sensors to operate the camera tilt and pan functions.
Thanks, Gary
The Samsung Galaxy Tab 2 7" Tablet seems about right
for the FPV viewing, and for running the DJI-Vision app.
Not recognized by the Play Store, but I downloaded the APK file
and it runs. I will need to try it with the P2V before I will really
know if it functions properly.
Does anybody know what functions the "display" needs to have?
Or, what the DJI-Vision app needs?
Kindle fire hd works fine also. You do need ti add the app using a special app installer app like the black market app or 1 market app.
What other Android devices are you using please?
See first post for a link to the latest DJI-Vision app APK file.
This file is useful for "side-loading" the app into Android devices
that the Google Play Store does not allow for this app.
Cheers, Gary
Just for fun I tested the app on my Transformer EEE pad (Android 4.0.3), and it's working fine.
Please note that this was flying inside a big garage.
Hi all! I just placed an order for a P2V. As I would prefer to use a tablet instead of my smartphone to control the Vision, can you tell me if the above referenced tablets will fit in the smartphone holder that comes with the Vision?
No Tablets fit?
It would depend upon the size of the tablet, right?
Well..., maybe there are not any tiny tablets. :oops:
Would 4.37 inches fit (the Samsung Galaxy Tab 3 7.0 inch tablet)?
Perhaps somebody would actually measure the wide-open dimension of their
smartphone clamp, and report it here, please?
I might have to 3D print a 5" high tablet adapter.
Pull_Up said:
I've just measured it. At full stretch the max distance is 9.5cm or 3.75 inches between the jaws.
Wow! 3.75 inches - so near yet so far. It would be nice if DJI offered a clamp with about a half inch more room in it as an accessory .
This is what I did for my iPad Mini. I got a holder for the iPad with the threaded back from Grifiti.
This is my new setup using a Seasucker vacuum cup to hold any tablet. It is secure and clean and does not interfere with the controls.
Here is how I mounted my Galaxy Tab 3.
Short piece of 1X2 with quarter round tacked to the two long edges.
Attach to tablet with sticky back velcro.
The curve of the quarter round fits the curve of the clamp almost perfectly.
I happened to have some white vinyl material from Home Depot on hand so I didn't have to paint it, but wood would work just as well.
designerbags
