Feel free to list them out here.[/QUOTE
See this forum, FB, DJI forum, Youtube, elsewhere. No need for me to duplicate what is already out there (unless you are a DJI engineer, at which point your own forum moderators should have given you enough to mull over for the next month). 2 from FB only (100s of others):
P M. I accidently updated the app.... so went through with the new firmware.... took me two days to get it completed.... and I've had nothing but issues with my monitor, skipping and breaking up... prior to this it was rock solid... never skipped a bit.... zero issues .... now even a at a dozen feet out it starts breaking up ...... Man, I dreaded that update. There is a place where I can downgrade but I worry about how to downgrade the controller too. I purchased Litchi and am in hopes that it will fix it.
CM.Hi people. I'm facing an annoying problem trying update to the latest version. The process goes as normal but when I turn on the RC, the led blinks red/green, the app says it is connected but the downlink video is horrible. I've tried re-linking the RC turning off both devices and then turning on the RC, after that turning on the aircraft and going directly to the "Link RC" option. No luck. It flash cyan/blue and confirms it is linked, but still flashing and the video is broken; actually sometimes I get the "No signal" alarm.
I went back to the previous version and it goes back to normal, actually the RC is already linked with solid green; the FPV is also stable as usual. Any insights?
