GPS display
Hello, is there a way to see GPS coordinates while flying? I have a Phantom 4 Obsidian.
Thank you
DJI GO does not show that information. If you're not opposed to using a 3rd party flight app, you can see that location when flying with Litchi.
Reactions: Capt KO
The major cons for me are that it doesn't keep good flight logs and DJI support will want nothing to do with the flight logs if you run into an issue that requires the flight logs to be analyzed. Litchi is the way I'd go though if I needed the coordinates in realtime for a specific flight.
Thank you very much. It will be on a limited basis so i may give it a try. Thanks again
husseinijewels
