immersionRC and power from balance plug
Quick question
What is th easiest way to power my transmitter? I read th balance plug, but how or where do i get this cable?
Thoughts??.
There should be an aux power lead (grey/red) on the Phantom that you're probably already using to power your gimbal. If so, you can split that power lead off to the transmitter and power that as well.
If the power connection for your gimbal is using the common JST plugs (red), you can split the power off with one of these: http://www.readymaderc.com/store/index. ... cts_id=536
From there, you can connect that to your Immersion Tx with one of these: http://www.getfpv.com/fat-shark-2p-mole ... cable.html
Readymaderc sells that 2nd cable too, but they happen to be out of stock right now.
By the way, thanks to you both. I appreciate the help for a newbie
There's a lot of conversation for phantom 2 but not much coming in search for phantom 1.1.1
It has not arrive yet. I as trying to get everything ordered so it would arrive at the same time approximately lol
WHOO HOOO
Monitor arrived today.
Plugs on the monitor are Female RPSMA
Plug on the transmitter is Female SMA
Based on that, what do you recommend for antennas?
Starbase
