FatShark SpiroNet Antenna questions
Malaysia
I'm using a Black Pearl 7" FPV Diversity Rx 5.8 with SMA antenna port. Bought the fatshark SpiroNet SMA and needed to add and SMA-RPSMA adaptor in order to install the antenna.
Is there any difference in output or receiving power of the the black (sma) and grey (rp-sma) FatShark SpiroNet 5.8GHz Antenna
black (sma)
http://www.rc711.com/shop/fatshark-spir ... -8131.html
grey (rp-sma)
http://www.rc711.com/shop/fatshark-spir ... -8722.html
Possible to use it with a SMA-RPSMA adaptor or it's more advisable to return and reorder a grey fatshark (rp-sma)
Plz advise.. Thanks a bunch! :D
black (sma)
grey (rp-sma)
I think the only difference is the connector on the end. If you're using a ImmersionRC TX and a Black Pearl RX you're going to need an adapter either way. Which antenna set you buy SMA or RP-SMA only determines if you need the adapter on the RX or TX end. I was in the same position you are in now and had to order an adapter for my BP. This is what you will need.
http://www.amazon.com/gp/product/B00CVQ ... UTF8&psc=1
So there is nothing adverse with using an adapter at either the Tx end or Rx end when you are speaking of RP-SMA vs SMA?
And all i need is one adapter Female RP-SMA to Female SMA?
Do you know what polarization is the DJI AVL58?
black (sma)
grey (rp-sma)
yeah. that's the exact adaptor I use :) Thanks for the other update
canadiansauna
