Controller USB board
Hi Guys,
Is there a way that I can test the USB board on my controller?
As I have just upgraded my controller to be boosted with dual amplifiers. But after the upgrade I am not able to get a picture or any telemetry on my tablet. I get a green light on the controller meaning there is a connection there but no video etc.
I have not changed anything else since installing the amps and it worked fine before.
I am not looking to upgrade any firmware until I can get a video signal as 1 problem at a time is enough.
I have a P3A
I have just purchased a new Controller ribbon cable as my first step to resolving this issue
beside the ribbon cable which you need to disconnect to open the controller up, I did not disconnect anything else....
I had already installed the MAXXuav clean install kit and the dbs antenna which was installed correctly and I had working before I added the amps into the mix.
Other than the USB board itself being the cause of the issue I am lost for answers
Call the support of the people that made the "amp" ! hope the problem get solved asap !
Reactions: With The Birds
I dont think the error is with the amps.
As I get a green light at the bottom of on my controller even with the amps turned off.
Read Post Number 3 again ! Good Luck.
seocompanycalct
