Broken remote antenna, SOLVED!
Less than $10.00 fix. Items needed, RP-SMA Male 2.4Ghz-5.8Ghz 3dbi antenna($1.99 at Banggood.com), and U.FL Mini PCI to RP-SMA Female Pigtail 8-10 cm Antenna WiFi cable($2.99 at Banggood.com). Clear JB Weld 2 Part Epoxy #50112 (Walmart $4.40) Easy fix!
Have you tested the range with this mod yet?
I've done this fairly standard mod but with a 5DBi antenna on several remotes for my other brand drones (Syma/MJX Bugs 3 etc) to replace the kiddy-type simple wire antenna and it's increased the range considerably.
Luckily I've never broken either antenna on my P3P and I'd go for one of the proprietary booster kits if I did though.
This antenna is the same as the standard antenna. One can always upgrade to a larger DBI antenna.
thedrinklabsus
