Backpack
Has anyone tried to mod their p3 backpack somehow so the p4 can fit? Is that possible?
I've seen a few people modify the P3 DJI hard shell backpack by simply cutting the foam to make the P4 batteries fit, you,loose that little space above the batteries but it wasn't really a useful space for much anyway.
I just did it yesterday to a P3 DJI hard shell that I picked up from MicroCenter for $29
You also need to cut the landing gear slots longer and wider, also some slots for the gimbal guard.
It wasn't hard, I heated up a box cutter blade with a butane torch and it helped keep the cuts clean. I can fit 3 P4 batteries where the P3 batteries used to go.
Reactions: Cale262
Cheap foam cutter! [emoji15] it's showing $99 on that link... Hat ain't cheap. Ha ha. I'll stick with my method that is essentially the same but at about 50c. [emoji4]
Johnboy94
