Heya guys,
Thanks to this topic i fixed a Esc problem but that ones fixed and now a other problem raised...
my front LED do not lighten up red after i start the drone....
does anyone know this problem or can anyone tell me where the signal from the LED comes from ?
is it the same cable that comes from the M1-M4 ports on the phantom FC or is it the LED Port that goes down with a cable to the USB Section.
Hopefully you know it !
Greetings,
Robin
Hi!
Both commnets are really helpful and appreciated!
I will check the resistance, but I presume that it was 0 ohms if I remember well.
And jarance, indeed, I see that the main issue with the voltage could also be the fact that L1 is not present. I will receive a replacement this week.
In the meantime I will figure out if I am able to discover the path of the 5V... Which looks to me like a whole new layer (5th one in between the two 12V ones:
layer one has a big X (or K) visible on top to provide ground to ESC
layer two should follow a similar path to provide 12V to ESCs
layer three would be the same
layer four again a visible X to provide ground to ESC.
So since the 5 V would go from the MP2482 to the FAN net, it should cross the ESC paths, with those X paths... lets see!
Thanks!
You know of course that is a two sided board.
It is at least a 4 layers board.... I can attach some pictures later if needed, but below the top and bottom layers there are another two ones... at least, and I think that there might be a 5th one...
Well, I have this need of bringing back to life broken items, and I found this as a nice challenge . On top of that I can learn a lot from it, and eventually bring some relevant info to the forum!So why not just replace the board??
