Video: Installing a Tilt Control Knob on Stock Transmitter
Re: Video: Installing a Tilt Control Knob on Stock Transmitt
Does it also apply to modified potentiometer knob of 5K ohms?
I haven't myself, my pot is coming in the post but I've seen enough people with gimbal control problems. You have to go through that procedure when changing pots or gimbal isn't moving properly. Yes especially applies if you have changed pots.
Thanks again Sir Mrc.. hope it will be solved soon.. I am worried calibrating on the RC software.. I usually calibrate on the phantom 2 software..
Don't worry about calibrating in RC software, it is no problem. Calibrate sticks and pot in RC software, then calibrate both again in phantom software. Only takes a few mins.
Remember when calibrating in RC software to have the remote connected to computer and when calibrating in phantom assistant to have the phantom connected to computer (remote turned on).
Thanks for the info.. I did exactly as you instructed and there it goes.. problem was solved. Thanks a lot
Hi ,
This is an excellent video. I Would like to do this mod, but wondering , is this compatible with the DJI Phantom Vision, Not the Vision +?
Thank you much :)
Jerry P
