Upgrade Cam/Gimbal on P3A - Downgrade To P3P To v.01.07.00 Firmware
hph
The title explains what I wish to do - add the P3P 4k camera and gimbal to the P3A. All the posts here and otherwise say I also need to install the P3P firmware so the upgrade cam/gimbal operates OK.
Has anyone successfully installed an older version (01.07.00) of P3P Firmware via the micro SD card on a P3A currently with its 01.10.90 firmware, or other later firmware, and have everything work OK afterwards?
If so, what was your procedure?
'ppreciate your input, cause inoperative P3As make expensive paperweights, bricks, whatever!!!
ive done a p3a camera on a p3p body (yours is the opposite). Just make sure you flash it with the right firmware, P3P firmware will start with P3X.
I'm not a big fan of jumping firwmare .. i would go down one by one to 1.8 first, then 1.7. Make sure you use the p3x firmware, may need to use the debug file as well. If you log doesnt show "success", delete the debug file and re-run the fw update and it will finish up and the log will then show success.
stovebayga
