- Joined
- Oct 20, 2017
- Messages
- 31
- Reaction score
- 9
- Age
- 45
Thanks! Sometimes no matter how long you look at something you just don't see where it is. Have a great weekend.Try settings->Personal->security->Unknown sources
This should do the trick.
I mainly use the Litchi app. Can it be added to the BT300's ? I just ordered a set to use with my Phantom 4 as the DJI goggles are horrible with anything but the Mavic.
Thanks for the response ! You actually have to use a hacked version of the litchi app. I purchased Litchi for Android and took the APK off of the phone and side loaded it onto the BT300 but it wont load as you have to log into Google Play which you cant do with the BT300's. I sent Litchi support a e-mail and here is the response ..
Litchi does work on the BT-300 you have to use version 4.0.2, that is one that is compatible with Android 5.1 which the BT-300 uses
Actually if you could log into Google Play you could use the most recent version. Litchi 4.0.2 that is out on the internet is a patched version where it doesnt have to log in to get the license.
Yes, that is the reason why you have to use the patched version of Litchi as you can't full install the google play store for authentication.
I don't believe the google play store will ever be supported by Epson as they have already developed there own apps store.
However apps that exist on the Amazon apps store will work on the BT-300
