- Joined
- Apr 14, 2018
- Messages
- 85
- Reaction score
- 16
- Age
- 58
I'm on day two of owning a new P4P v2.0 and am about to return it due to the horrible range I am getting out of it. The first day I could barely get it off the ground in my backyard (a 50ftx50ft grass area) because the signal seemed to be dropping out so bad. I live in a suburb of Phoenix so it is not the most ideal area but this is ridiculous! Throttle up and it would climb a foot or so then sputter/freeze, up a foot then freeze etc...yaw left or right, no response with the stick held in place then a small bump in the direction I commanded then stop, move a little then stop...same with pitch and roll. I varied my distance from remote to drone between 5ft and 30ft with no change whatsoever. Video transmission was just as bad. Strong interference was showing under signal quality.
After my first flight I see the DJI Go 4 app found a new firmware version so I update to V01.00.1500. I now have DJI Go 4 version 4.2.21 (5th gen Ipad--2017 model), and version 01.00.1500 showing on both the controller and Phantom. Second flight was worse than the first, I did an auto take-off and lost all control of my Phantom as it hovered 30ft above me. As I wondered around my yard trying to figure out how to get it back on the ground without incident it began to intermittently respond to stick commands. From 30ft up it took half the battery charge to bring it down and land because it would only come down a foot at a time then stop because the signal kept cutting out.
By now I'm scared to death to fly this thing even though I have been an r/c modeler with 25+ years experience flying planes, helicopters, and fpv racers. I call it a day and decide to research range problems other people might be having that could help my situation. I find what I think is the golden ticket--relinking the remote with the Phantom. I do this at home and everything seems to work now. Signal quality shows good. Not wanting to tempt faith, I go to the park behind my house where I fly previously said planes/helis/drones and do another relink. Take-off manually and it is responding correctly to all inputs--sweet! I take it out and up in 25ft increments. Get to 291ft up and 553ft away (yes FEET, not meters) and I'm thinking all is well. I start doing some pictures and video then pfffffffffttttt!! Unresponsive! Uh Oh! Same thing happens again and it takes most of the battery to work it back and down a foot at a time until it's on the ground 5ft in front of me still experiencing severe "interference". So bad so that it takes more than a minute before I can power the darn thing off with left stick full down. P.S. In order to isolate the problem my cell phone and the Ipad I was using DJI Go on where both in airplane mode for the whole flight.
At all times VLOS was kept, transmitter antennas were positioned to be perpendicular to direction of travel...Is this a common occurrence when flying in an urban environment with DJI equipment? I think not but I contacted DJI support earlier today and they gave me the boiler plate "interference can affect range" statement. I've never run into such a finicky signal before with my other 2.4 ghz radios and can't see how this is normal.
Can those versed in urban flight ops with a P4P and/or P4P V2 please comment on what they have seen for range? And if you needed to change any settings to achieve that range?
Thanks for reading!
D
I’m very sorry to read this I was just thinking about getting the new one and I just purchased the phantom for pro two weeks before they came out with the one you bought now I’m noticing cracks under the back motor in the plastic on both sides and I’ve only took it up maybe 30 times it has been nothing but problem after problem with this drone my Mavic pro is still almost perfect somebody needs to take these guys to court maybe I’ll be the first one because I want my money back
