PHANTOM 2 VISION PV330
Hello Everybody
I had the PV330 long time ago but we just turn it on one time then left it , now i comeback and try to switch it on , but its seems there is issue with it,when i switch it on all lights for the 4 wings flashing, Red,Green , Amber , then i hear music , then two music alarm with the two wings light which is infront the camera plinking red then the red colour switch off and light stay off and the other wings light (behind the camera ) continue plinking Amber and there is light with rest button continue plinking red.
Please for whom have experience how to fix that,i hope you can advice me
Mushtaq
Hello Mushtaq,
It could be several things!
RF Interferance
Tx not bound
Compass need calibrating
IMU needs calibrating
Tx needs calibrating
GPS issue
ATTI mode on
Make sure all toggles are UP on your Tx.
Are you turning it on inside?
Or outside?
If inside, try a new location.
Can you take a video for us? So we can see!
Until then try these things:
First
Make sure Tx's is bound to bird
( turn on bird only ) let it start up, you should get a fast Amber blink.
Then turn on Tx, lights should change, if not, turn off Tx, leave bird on, push RESET button on bottom of phantom ( blinking red light TINY LIGHT BY LANDING GEAR ) until it turns yellow, now turn on Tx, it should bind
Next
Hook Tx to RC ASSISTANT, calibrate all sticks, toggles, dial wheel, if you have a dial wheel?
Now
Hook phantom to PC ASSISTANT,
Do an advanced IMU CALIBRATION, calibrate Tx there as well , then go outside, do a fresh compass calibration. These things should fix your problem.
If not something more involved is going on, maybe a bad battery?
Red lights can mean system error, if battery is bad.
Let us know
J Dot
Take care, Fly safe.
Hello J Dot
Thank you for your answer , i have download thePhantom 2 Vision+ Assistant Software v3.8 program as you advised, and upgrade the firmware of the system made screen shoot for the program pages after trying the calibration and i have problem with X1 , where it was not responding when i change S1 switch,all other switch and sticks are responding
Below you can find the picture and link for video for the starting status.
Dropbox - Video Feb 05, 3 14 39 AM.mov
Thank you for your help and support.
Mushtaq
Hello Mushtaq,
RF Interferance
Tx not bound
GPS issue
ATTI mode on
Or outside?
First
Next
Now
Let us know
J Dot
Hello again, Mushtaq,
Ok
Everything looks good on settings, but a couple things.
1) X1 is ( dial wheel, or 7th channel mod )
If you have neither, you cannot calibrate X1 ( X1 is not your toggles )
2) if you do not have a dial wheel remote, or do not have the 7th channel mod installed on your remote ( than change the setting ( UPGRADE REMOTE ) to BASIC REMOTE!
This will keep camera from going straight down, and you will have control through vision app!
Ok
Now your video
It looks right, when you power the battery, you should get all arm blinking, with music, than BEEP-beep-beep-beep, when music stops, front arms turn off, ONLY rear arms light. Fast yellow ( no signal from Tx ) slow yellow ( ready to fly NON GPS MODE ) or waiting on satellite lock )
Slow green ( 6 satellites squired, ready to fly GPS MODE ) fast green blink ( home lock established )
Now
When you start motors to fly, you'll see front arms turn RED, back should be blinking green or yellow ( GPS or non GPS )
Also, when phantom is on , and you flip your RIGHT TOGGLE S1, up and down 6-8 times, does it go into compass calibration mode ( or solid yellow rear lights? ) if so than toggle works. Left toggle not used unless you go into NAZA MODE !
Take your bird outside, turn it on, wait till you get 6 satellites locked ( you can see in app ) you'll see those yellow blinks turn into green blinks, wait for home lock ( fast green blinks, followed by normal slow green blinks.
If so, go fly!
Here is a video of mine starting up ( I have version 2.1 esc's, so mine does not have the last 4 beeps ) but the same anyway:
Here is my other 2 ( like yours )
J Dot
Keep us updated!
src72
