phantom 2 vision plus gimbal lock error fix
the problem causing the gimbal lock error is not caused by the
main gimbal pcb board. I had that problem I found that if the yaw motor on top
of the gimbal (not the yaw arm) has the slightest bind on it (mine was very very slight)
it causes the error to appear on the screen
just thought it may help other members
Reactions: crash1sttime
Yes quite true, sometimes people reassemble them upside down and the arm drops, ive fell for that just once though. I know use a shim to set the gap.
Reactions: Mark The Droner
src72
