no start 4x green led acceleration - Y error
My phantom is doing the same thing and will not start, I hope someone here can help?
Thanks. :?
Are you guys using the phantom vision as this is the vision section? Either way have you tried doing an advanced calibration seeing as its showing am error. That should solve the fault if not you may have a faulty phantom. If somehow you got tue vision which I didnt think was out yet it may use a new firmware not compatible with the current naza software.
Check to see that you did not force the cable connector into the compass module the wrong way. It is NOT connected if you did this. The NAZA Assistant clearly shows that you are getting no sensory data from the compass.
ctlfreak
