Mount 2.4GHz Data Link inside or outside P2?
San Diego, CA
My PC GS will arrive in 2 days, I'm looking for advice on mounting the 2.4GHz Data Link hardware, my choices are mounting inside or outside the P2 (non-vision). Is there a preferred mounting for the Data Link on a Phanton 2 (non-vision)? Got any web links to examples?
Here is the inside mounting method. http://skypixel.org/post/83254735947
In case it matters, I will be using the PC GS, not the iPad GS version.
thanks,
thanks,
I'd recommend not to. You'll get too much interference.
Timsytanker said:
Mine is Velcroed underneath behind the gimbal.
Can I ask how you routed your antenna's? I have the iPad version and seemed to be getting some interference today when attempting the maiden GS voyage. Thanks in advance
I mounted mine inside and used the can bus leg for the antenna to come out, works perfectly fineI haven't checked for distance but based on the few flights I did this way, it worked just fine.
Also, I got rid of the external can bus and soldered the cables directly to the connector, the can bus is bulky for no reason, so I save a couple of grams there and I was able to put the GS and the iOSD inside the frame. What can I say, I like things neat in the outside and there's no reason for the GS to be outside as far as I can tell.
I mounted mine inside as well as moved the can bus inside on a shorter cable. To save some weight I removed the cases from the data link and iOSD and shrink wrapped them saving 16.7g.
I only got about 250 metres range when I put mine inside with 1 antenna coming out and down a leg and the other out the vent in the arm.
I dont like the GS datalink being on the inside because if I dont want to use it on a certain day You can't just take it out whenever you want, and its extra weight when your not using it.
I mounted mine underneath my phantom 2.
the cables bellow will allow you to mount inside or outside your phantom.
LINKS:
grace_arc | eBay
dji can bus cable | eBay
DonT
