Magic Mod on P3 Standard 1.9.20
Apologies for another magic power thread but I am having some issues.
I am on firmware 1.9.20 but I cannot use the magic powers mod. I have drilled down and worked out that I cannot telnet into the drone.
I can FTP but not telnet. I'm guessing this is something put in by DJI but does anyone know a workaround to be able to telnet on the latest firmware?
Nick
Start Magicpower in admin modus. Connect the P3 System via WIFI with your Laptop aor PC with WIFI module. It is also with 1.09.0200 too.
Reactions: KennethMcNutt
I did it without removing SD card with success but the Mp5.x must be started as Administrator to avoid adressviolation in Windows.
Sd card will not be affected through using Mp5.x You only chang values of the signal sterngth in the FW´s enviroinment on the RC and AC. They are stored on the internal SD memory and not on Cam´s SD card.
src72
