Is a Patch Antenna Worth the purchase?
Portugal
I have a question regarding my FPV setup.
My liliput only has 1 Antenna connector. I don't know if I should get the dual pack of IMMERSION RC 5.8GHZ RHCP V2's. Or if I should get 1 IMMERSION RC 5.8GHZ RHCP V2 for the transmitter and a 5.8GHz SpiroNET Mini Patch Antenna for the monitor?
Are there many benefits to using a patch? Will this setup work like I have stated or are patch antennas meant to be supplementary, used in conjunction with a standard antenna on say a Duo5800 – 5.8GHz A/V Diversity Receiver?
Thank you.
P2, GproHero3+Black
I used an omnidirectional and a patch antenna on my receiver/monitor. It will improve signal but keep in mind they are very directional, so you need to be aiming it at the aircraft at all times to get the full benefit. They are fairly inexpensive, get one and experiment with it.
Reactions: MotorCycle-Man
Honeymoo
