How does CS decide what network to connect to?
I would like my CS to connect to my 5GHz WIfi network as a default (vs the current 2.4GHz one it automatically connects to).
Is there a setting to make it check one before the other? I prefer NOT to delete the 2.4 one in case the 5GHz is down.
Thanks in advance.
I haven’t used android devices for a while. Hopefully someone will chime in with CS specific information. From memory there was a wifi setting called auto priority or something like that in saved networks. You could turn that off and then manually move your saved networks. Simply drag your preferred network to the top of the list.
Reactions: RickMz
Jesmith1016
