HELP! Zenmuse h3 2d
Hi, i got the dji zenmuse h3 2d, but on the box it dosent say that it is for the dji phantom 2. And the mounting brakets are like on the dji phantom 1.1.1. So will this gimbal work on my dji phantom 2 when i plig the plug in the zenmuse port? Or will it not?
Try the Google search link in my signature. I do not know the answer, but suspect you will be able to connect the gimbal to the P2.
on the box of my H3-3D on upper right corner of the box there's a sticker that says for phantom2 only.
check your box.
check your box.
I think you meant to quote the OP???
I don't have the P2 or the gimbal being discussed. I was just trying to provide the google search link.
You should be fine. On the H3-3D, there is a version specifically for the P2, which does not have its own gimbal control unit. The older 2D comes with a GCU as standard.
It may not be plug and play, but you will be able to fit it and wire it up
klik4d
