H4-3d Gimbal balance?
Hi Lads I have a P2 v2 with a gopro silver3+ and using a h4-3d gimbal, on ever flight the gimbal keeps tilting left then right then left then back to center . it does at random, so when climber or turning or on hover. I called the shop today and they said I need to use blue tac to balance out the gimbal / camera? anyone done this? does it work? just need to get this gimbal working and I will be loving this new hobby, thanks glen
Give this factory reset a try as this problem is not uncommon. Watch the video an it doesn't make any difference that is was for H3-3D gimbal this works on both.
Once you've completed the reset make sure to calibrate X1 in both controller and P2 software.
Hi Jason, thanks for the vid, I have seen this , but been a bit worried as I have read some people have had problems with resting the h4 3d, and was told by the shop to try the blu tac method. thanks again glen
src72
