Hi... Does anyone know if its possible to use the H3-2D with the latest incarnation of the P2 with the new transmitter. I've hooked it up and it works 'fine' except that the gimbal's resting position is tilted down due (i suspect) to the spring loaded gimbal dial on the new transmitter. Is there a firmware fix or anyway around this?
I thought that too. In the phantom assistant you can change the remote type - upgrade version or basic version. You want the upgrade version as you have the upgraded remote.
