GS Pro Resume Mission Feature
Hi, I'm in the middle of a multi-day Ground Station Pro 3D mapping mission and I have a question about the intricacies of the "resume mission feature" that directs the drone to fly to the last spot in the flight plan to continue mapping, typically after swapping out a battery. Does anyone know if the resume mission function is still available if I close the mission, reopen it, then edit a parameter or two? Though I could simply close the mission, edit the parameters, and adjust the mapping point to roughly where the drone stopped mapping, it would be much more elegant if an incompleted mission retained a pointer to the spot where the mapping should resume. Thanks.
To answer my own question, once a mission is closed, the program doesn't save a pointer to where the last photos were taken.
Is it possible to solder a couple of leads so you could jump it with a different battery, while doing a hot swap? Haven't really thought it through.
stovesparesdirectuk
