gps mod?
Halifax UK
hi guys my phantom 2 was bought november 2015 and just wondered if i need to do the copper tape mod on the gps?
read somewhere that some phantom does not need it as dji have already done that.
many thanks guys!
many thanks guys!
its hard to say but most likely not if a p2
easy enough to check and do, just open the top case
takes a little work but if you do you can check the gps antenna
if the original , may as well put a 4mm in for under $10
good luck and have fun flying!
Reactions: froggy8
thank you for the reply
i have had a look at teh 4mm antenna, unfortunately i cannot solder at all so im going to have to give that a miss.
shame really as its meant to improve the signal drastically
its one spot ,pretty easy to do but understand..
it truly does by the way make a big difference
did it to 2 p2's I had
btw alum duct tape for furnaces works well for shield
is this the antenna you are talking about?
DJI Phantom 1 and 2 GPS Antenna Upgrade 4mm | eBay
also i have just purchased this
DJI Phantom GPS Booster Shield | eBay
that appears to be the same as far as specs
I am in us and ordered direct to parts supplier and paid about $6 US
you want 4mm
at least 3 to5 db gain
if you do the mod you may want to scrape a bit if the plastic ribs under the area antenna sits to give a little more clearance since this is 4 vs 2mm high.
when you put top back on be careful to make sure gps wire is snug into mother board..
also use alum tape to wrap the gps wire as far as you can--no harm, no foal--
then cover with layer of tape
good luck and have fun flying.
once I change antenna the GPS lock time ( 2nd set green flash) was well under a minute and stayed locked...
Reactions: froggy8
I have not modded my P2 GPS and my lock is about 45 seconds after several days of non-use. This is about 15 seconds after mag./compass heading is established.
Reactions: froggy8
i havent even took it out yet to test it since i got it. my gps booster has arrived but not installed yet, still at work.
i am thinking about the gps module as its got really good reviews.
you want 4mm
this is the specs for the one i linked
Range of Receiving Frequency
Center Frequency
1575.42MHz +/- 1.023MHz
1575MHz +/- 3MHz
2 Impedance 50Ω
3 Bandwidth 10 MHz min Return Loss <-10dB
4 VSWR 1.2:1
Center Frequency
5 Gain toward Zenith 1.55 dBic typ.
6 Gain at 10°Elevation -2.5 dBic typ.
7 Axial Ratio 3dB Max.
8 Polarization Right Hand Circular Polarization
9
Frequency Temperature
Coefficient(τf) 0 ± 20ppm/°C
10 Operating Temperature -40ºC to +85ºC
Reactions: kirk2579
src72
