Gimbal working on startup
After new gimbal board I now have video feed and dance at startup, but does not compensate for ac movement. Did imu calibrate as well as compass calibration. Moved to backup se and same results. Thinking I got a bad gimbal board, UT it goes thru startup fine
Like FPV mode? Camera follows the Drone instead of the horizon? Just asking so somebody has a better idea of what's going on.
Gimbal is not stabilizing camera during flight, it stays with drone
Did you turn on FPV accidentally? I believe you have to turn it on manually each time, not sure. If on, turn off. If stuck, I don’t know.
Nwbailey
