- Joined
- Mar 14, 2020
- Messages
- 11
- Reaction score
- 5
- Age
- 66
What’s a compatible flifli air drop for a phantom 3 advanced for fishing
Yes miss fishing,,I just made this one ,,updated version of my first attempt,,just cable tie holds it in place,,can either do up reel drag or tilt back and swivel that holds trace just slides off into water,longest drop was 910ft due to that's all the line on my surfcaster,, downfall was winding it in,,electric reel be ideal,,,saves buying anythingWhat’s a compatible flifli air drop for a phantom 3 advanced for fishing
ne similar however I would like to be able to control where it drops rig instead of have to close the reel spoolYes miss fishing,,I just made this one ,,updated version of my first attempt,,just cable tie holds it in place,,can either do up reel drag or tilt back and swivel that holds trace just slides off into water,longest drop was 910ft due to that's all the line on my surfcaster,, downfall was winding it in,,electric reel be ideal,,,saves buying anything View attachment 118059View attachment 118060
Ah I see,,this might be better for more of controlled drop,there's couple on Ebay, price ok to,,this one has remote to dropI’ve do
I just got a flifli airdrop have tried it yet but seems like it will work fun has anyone run into problems while flying itI’ve do
Only if it snags on something. Hard to release in a panic, you crash. Have fun. ?I just got a flifli airdrop have tried it yet but seems like it will work fun has anyone run into problems while flying it
Yeah like every drone gotta keep an eYe on flight and battery lifeOnly if it snags on something. Hard to release in a panic, you crash. Have fun. ?
You can always put your own release clip in-line. Heavy duty Clothes pin type so something will give, before crashing. Even an outrigger release clip could work. Use a light weight clip because it will come down when releasing your load from Flifli. FunOnly if it snags on something. Hard to release in a panic, you crash. Have fun. ?
I have a small release that works fine. ThxYou can always put your own release clip in-line. Heavy duty Clothes pin type so something will give, before crashing. Even an outrigger release clip could work. Use a light weight clip because it will come down when releasing your load from Flifli. Fun
